I am trying to install mongodb 7.0 version, I have followed all pre requisite commands, and installed all the dependencies. However getting error while executing "sudo apt install mongodb-org -y" command. please assist me with answer.
Output:-
root@test-vm-2:~# apt install mongodb-org -y
Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
The following packages have unmet dependencies: mongodb-org : Depends: mongodb-org-database but it is not going to be installed E: Unable to correct problems, you have held broken packages. root@test-vm-2:~# root@test-vm-2:~#
