I am trying to install Virtual box but it keeps giving me problems, the manager window will open fine but it keeps giving me this message in the terminal.
WARNING: The character device /dev/vboxdrv does not exist.
     Please install the virtualbox-dkms package and the appropriate
     headers, most likely linux-headers-generic.
 You will not be able to start VMs until this problem is fixed.
I reinstalled it and then I had these errors in installation.
× virtualbox.service - LSB: VirtualBox Linux kernel module Loaded: loaded (/etc/init.d/virtualbox; generated) Active: failed (Result: exit-code) since Thu 2024-09-19 11:25:15 +03; 1min> Docs: man:systemd-sysv-generator(8) Process: 34263 ExecStart=/etc/init.d/virtualbox start (code=exited, status=> CPU: 45ms
Sep 19 11:25:15 Moudi systemd[1]: Starting virtualbox.service - LSB: VirtualBox> Sep 19 11:25:15 Moudi virtualbox[34263]: * Loading VirtualBox kernel modules... Sep 19 11:25:15 Moudi virtualbox[34263]: * modprobe vboxdrv failed. Please use> Sep 19 11:25:15 Moudi virtualbox[34263]: ...fail! Sep 19 11:25:15 Moudi systemd[1]: virtualbox.service: Control process exited, c> Sep 19 11:25:15 Moudi systemd[1]: virtualbox.service: Failed with result 'exit-> Sep 19 11:25:15 Moudi systemd[1]: Failed to start virtualbox.service - LSB: Vir> lines 1-14/14 (END)...skipping... × virtualbox.service - LSB: VirtualBox Linux kernel module Loaded: loaded (/etc/init.d/virtualbox; generated) Active: failed (Result: exit-code) since Thu 2024-09-19 11:25:15 +03; 1min 59s ago Docs: man:systemd-sysv-generator(8) Process: 34263 ExecStart=/etc/init.d/virtualbox start (code=exited, status=1/FAILURE) CPU: 45ms
Sep 19 11:25:15 Moudi systemd[1]: Starting virtualbox.service - LSB: VirtualBox Linux kernel module... Sep 19 11:25:15 Moudi virtualbox[34263]: * Loading VirtualBox kernel modules... Sep 19 11:25:15 Moudi virtualbox[34263]: * modprobe vboxdrv failed. Please use 'dmesg' to find out why Sep 19 11:25:15 Moudi virtualbox[34263]: ...fail! Sep 19 11:25:15 Moudi systemd[1]: virtualbox.service: Control process exited, code=exited, status=1/FAILURE Sep 19 11:25:15 Moudi systemd[1]: virtualbox.service: Failed with result 'exit-code'. Sep 19 11:25:15 Moudi systemd[1]: Failed to start virtualbox.service - LSB: VirtualBox Linux kernel module. ~
I tried all the suggestions in that old post except disabling secure boot because it doesn't seem like a good idea. I got this:
Job for virtualbox.service failed because the control process exited with error code.
See "systemctl status virtualbox.service" and "journalctl -xeu virtualbox.service" for details.
invoke-rc.d: initscript virtualbox, action "restart" failed.
 Active: failed (Result: exit-code) since Sat 2024-09-21 12:57:26 +03; 20ms ago
Process: 66621 ExecStart=/etc/init.d/virtualbox start (code=exited, status=1/FAILURE)
    CPU: 44ms
Sep 21 12:57:26 Moudi systemd[1]: Starting virtualbox.service - LSB: VirtualBox Linux kernel module... Sep 21 12:57:26 Moudi virtualbox[66621]: * Loading VirtualBox kernel modules... Sep 21 12:57:26 Moudi virtualbox[66621]: * modprobe vboxdrv failed. Please use 'dmesg' to find out why Sep 21 12:57:26 Moudi virtualbox[66621]: ...fail! Sep 21 12:57:26 Moudi systemd[1]: virtualbox.service: Control process exited, code=exited, status=1/FAILURE Sep 21 12:57:26 Moudi systemd[1]: virtualbox.service: Failed with result 'exit-code'. Sep 21 12:57:26 Moudi systemd[1]: Failed to start virtualbox.service - LSB: VirtualBox Linux kernel module. moudi@Moudi:~$ dmesg dmesg: read kernel buffer failed: Operation not permitted
Moudi
