The auth.log showed me the following, where I log in & sudo twice in a row (apologies for dodgy spacing, but it was just running lines together):
Sep 19 15:45:23 <server> sshd[4449]: Accepted publickey for <user> from 212.100.25.223 port 44560 ssh2: RSA SHA256:dat4CCgbWGDp06cC5qI1G4rjy5G6dSkbYdIRChVz3l0
Sep 19 15:45:23 <server> systemd: pam_unix(systemd-user:session): session opened for user <user> by (uid=0)
Sep 19 15:45:29 <server> sudo: : TTY=pts/1 ; PWD=/home/<user>; USER=root ; COMMAND=/usr/bin/su
Sep 19 15:45:29 <server> sudo: pam_unix(sudo:session): session opened for user root by <user> (uid=0)
Sep 19 15:45:29 <server> su: (to root) <user> on pts/2
Sep 19 15:45:29 <server> su: pam_unix(su:session): session opened for user root by <user>(uid=0)
Sep 19 15:46:55 <server> sshd[4607]: Accepted publickey for <user> from <IP> port 58146 ssh2: RSA SHA256:dat4CCgbWGDp06cC5qI1G4rjy5G6dSkbYdIRChVz3l0
Sep 19 15:46:55 <server> sshd[4607]: pam_unix(sshd:session): session opened for user <user> by (uid=0)
Sep 19 15:46:55 <server> systemd-logind[796]: New session 12 of user <user>
Sep 19 15:47:01 <server> sudo: pam_tally2(sudo:auth): user <user> (1012) tally 38, deny 5
That appears to be showing that the logins are accepted by pam_unix. However, there's a difference with the second session. The first shows a " systemd: pam_unix(systemd-user:session): session opened " message, the second doesn't. This is followed by the sudo attempt. The first works with "sudo: pam_unix(sudo:session): session opened for user root", while the second shows "sudo: pam_tally2(sudo:auth): user (1012) tally 38, deny 5".
That led me to a SUSE page which discusses this issue, and provides a workaround:
https://www.suse.com/support/kb/doc/?id=000018034
In both cases, the tally of failed logins increases rather than resets on successful authentication. Changing the following line in /etc/pam.d/common-auth works around the issue by setting the acceptable number of failed logins stupidly high:
auth required pam_tally2.so onerr=fail audit silent deny=50000 unlock_time=900
(deny was 5 previously).
I also looked at the services running on this server and noted the following:
● sssd-nss.socket loaded failed failed SSSD NSS Service responder socket>
sssd-pac.socket loaded active listening SSSD PAC Service responder socket>
● sssd-pam-priv.socket loaded failed failed SSSD PAM Service responder privat>
● sssd-pam.socket loaded failed failed SSSD PAM Service responder socket>
I haven't had a chance to look into those yet, but at least I can do so now that I can successfully elevate my account using a valid password!
Thanks to @steeldriver for the suggestion that got me to this point
