I am trying to install top tracker provided by Toptal. I am getting this error
*sudo dpkg -i ~/Downloads/toptracker_1.6.2-6524_amd64.deb
[sudo] password for user:
Selecting previously unselected package toptracker.
(Reading database ... 204997 files and directories currently installed.)
Preparing to unpack .../toptracker_1.6.2-6524_amd64.deb ...
Unpacking toptracker (1.6.2-6524) ...
dpkg: dependency problems prevent configuration of toptracker:
 toptracker depends on libappindicator1; however:
  Package libappindicator1 is not installed.
dpkg: error processing package toptracker (--install):
 dependency problems - leaving unconfigured
Processing triggers for gnome-menus (3.36.0-1.1ubuntu3) ...
Processing triggers for desktop-file-utils (0.27-2build1) ...
 toptracker*
when I tryed to install libappindicator1 then getting
sudo apt-get install libappindicator1
Reading package lists... Done
Building dependency tree... Done
Package libappindicator1 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libappindicator1' has no installation candidate
Can anyone let me know how to fix this ?
muru
  • 207,228
Download libappindicator1
wget http://mirrors.kernel.org/ubuntu/pool/universe/liba/libappindicator/libappindicator1_12.10.1+20.10.20200706.1-0ubuntu1_amd64.deb
Download dependency required by libappindicator1
wget http://mirrors.kernel.org/ubuntu/pool/universe/libd/libdbusmenu/libdbusmenu-gtk4_16.04.1+18.10.20180917-0ubuntu8_amd64.deb
Install both packages
sudo apt install  ./libappindicator1_12.10.1+20.10.20200706.1-0ubuntu1_amd64.deb ./libdbusmenu-gtk4_16.04.1+18.10.20180917-0ubuntu8_amd64.deb
Install forticlient downloaded from https://www.fortinet.com/support/product-downloads
sudo apt install ./forticlient_vpn_7.4.0.1636_amd64.deb
*Downside: using XFCE, the Network-Manager conflicts and disappear: so to restore ethernet/wifi connections, you will need to use nmtui toll
To install the toptracker_1.6.2-6524_amd64.deb file in Ubuntu 24.04 change directories to the directory that contains the toptracker_1.6.2-6524_amd64.deb file that you downloaded, open the terminal and run the following commands.
wget http://mirrors.kernel.org/ubuntu/pool/universe/liba/libappindicator/libappindicator1_12.10.1+20.10.20200706.1-0ubuntu1_amd64.deb http://mirrors.kernel.org/ubuntu/pool/universe/libd/libdbusmenu/libdbusmenu-gtk4_16.04.1+18.10.20180917-0ubuntu8_amd64.deb
sudo apt install ./libdbusmenu-gtk4_16.04.1+18.10.20180917-0ubuntu8_amd64.deb ./libappindicator1_12.10.1+20.10.20200706.1-0ubuntu1_amd64.deb ./toptracker_1.6.2-6524_amd64.deb
karel
  • 122,292
  • 133
  • 301
  • 332
