I am new to Ubuntu and decided to use ChatGPT to help me fix a graphical problem. My PC no longer boots. I will try to share chat when available (currently I get error every time i click 'share').
Ubuntu 22.04 boots to a black screen with a visible cursor solution step was already done, so it was of no use on my PC.
System Specifications:
- OS: Ubuntu 22.04.5
- Kernel: 6.8.0-40-generic
- CPU: Intel i9 gen-13
- GPU: NVIDIA RTX 4090
- NVIDIA Driver Version: 555.58.02
- Desktop Environment: GNOME
- Display Manager: GDM (gdm3)
When I boot my system, it goes to a black screen with a blinking cursor in the top-left corner instead of the graphical login screen. I can access TTY terminals using Ctrl+Alt+F1 through F6, but the GUI does not start.
System logs for error testing:
(used image2text and a lot of manual typing, so there may be slight output errors)
- startx
fatal server error: (EE) failed to create screen resources(EE)
(EE) Server terminated with error (1). Closing log file.
xinit: giving up
xinit: unable to connect to x server: connection refused
xinit: server error
- sudo systemctl status gdm
gdm.service - GNOME Display Manager
Loaded: loaded (/lib/systemd/system/gdm.service; static)
Active: active (running)
Gdm: GdmDisplay: Session never registered, failing
Gdm: Child process was already dead.
gdm-launch-environment]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Gdm: GdmLocalDisplayFactory: maximum number of X display failures reached: check X server log for errors
- sudo journalctl -p err -b
gdm-launch-environment][5812]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
systemd[5244]: Failed to start Dunst notification daemon.
systemd[5244]: Failed to start Daemon to manage razer devices in user-space.
kernel: i2c i2c-2: Failed to register i2c client ITE8853:00 at 0x4e (-16)
kernel: Serial bus multi instantiate pseudo device driver INT3515:00: error -ENXIO: IRQ index 1 not found
kernel: uvcvideo 1-3.3:1.1: Failed to set UVC probe control: -32 (exp. 26).
kernel: iwlwifi 0000:06:00.0: Invalid buffer destination
kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.PEG1.PEGP._DSM], AE_ALREADY_EXISTS
- cat /var/log/Xorg.0.log | grep "(EE)"
(EE) [drm] Failed to open DRM device for (null): -2
(EE) [drm] Failed to open DRM device for pci:0000:01:00.0: -19
(EE) Unable to find a valid framebuffer device
(EE) open /dev/fb0: No such file or directory
(EE) Screen 0 deleted because of no matching config section.
(EE) Device(s) detected, but none match those in the config file.
(EE) no screens found(EE)
- lspci -k | grep -EA3 'VGA|3D'
VGA compatible controller: NVIDIA Corpotation Device 2684 (rev a1)
Subsystem: ZOTAC International ltd device
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidi*a
- nvidia-smi
No errors. Graphics card and driver both appear.
