61
jonquil@jonquil-Satellite-L755D:~/Downloads/akonadi-googledata-1.2.0/build$ cmake ..
-- The C compiler identification is GNU
-- The CXX compiler identification is unknown
-- Check for working C compiler: /usr/bin/gcc
-- Check for working C compiler: /usr/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
CMake Error: your CXX compiler: "CMAKE_CXX_COMPILER-NOTFOUND" was not found.   Please set CMAKE_CXX_COMPILER to a valid compiler path or name.
CMake Error at /usr/share/cmake-2.8/Modules/FindKDE4.cmake:98 (MESSAGE):
  ERROR: cmake/modules/FindKDE4Internal.cmake not found in
  /home/jonquil/.kde/share/apps;/usr/share/kubuntu-default-settings/kde4-profile/default/share/apps;/usr/share/kde4/apps
Call Stack (most recent call first):
  CMakeLists.txt:6 (find_package)
CMake Warning (dev) in CMakeLists.txt:
  No cmake_minimum_required command is present.  A line of code such as
    cmake_minimum_required(VERSION 2.8)
  should be added at the top of the file.  The version specified may be lower
  if you wish to support older CMake versions for this project.  For more
  information run "cmake --help-policy CMP0000".
This warning is for project developers.  Use -Wno-dev to suppress it.
-- Configuring incomplete, errors occurred!
With autotools I get this:
jonquil@jonquil-Satellite-L755D:~/Downloads/akonadi-googledata-1.2.0/build/build$ autoreconf -i -f
Can't exec "libtoolize": No such file or directory at /usr/bin/autoreconf line 196.
Use of uninitialized value in pattern match (m//) at /usr/bin/autoreconf line 196.
autoreconf: `configure.ac' or `configure.in' is required
xjonquilx
  • 1,497
  • 19
Install build-essential Install build-essential if you haven't done so already. You can install it in the Software Center or with:
sudo apt-get update && sudo apt-get install build-essential
peterretief
  • 1,308
21
gcc does not contain g++, these are different packages. Install g++ Install g++:
apt-get install g++
Thomas
  • 1,666
I am aware that this is "Ask Ubuntu", but if someone with Fedora would meet this problem, the following helped me:
sudo dnf install gcc-c++
Kepler
  • 71
