I have linux ubuntu 22.04. I want to update linux but /boot partititon is full. I would like to get some space free. I have already done kernel parititions and inftrams and apt autoremove or apt autoclean but i can't get more space. Is there a solution I haven't tried or do I have to reinstall linux? Some info is in spanish. all of the disc space is for ubuntu, i dont have other systems. ihave almost 500 mb for boot. i have that space and dont have separated as one friend reccommended so
i have seen other post but i cant fix it as ive done all, incuding unistalling “uninstall” kernels. that is the reason why i posted this
Here's some information:
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.4 LTS
Release: 22.04
Codename: jammy
$ uname -r 6.5.0-45-generic
$ ls /boot config-5.15.0-117-generic memtest86+.bin config-5.15.0-119-generic memtest86+.elf config-5.19.0-46-generic memtest86+_multiboot.bin config-6.2.0-37-generic System.map-5.15.0-117-generic config-6.5.0-44-generic System.map-5.15.0-119-generic config-6.5.0-45-generic System.map-5.19.0-46-generic config-6.8.0-40-generic System.map-6.2.0-37-generic efi System.map-6.5.0-44-generic grub System.map-6.5.0-45-generic initrd.img System.map-6.8.0-40-generic initrd.img-5.15.0-117-generic vmlinuz initrd.img-5.15.0-119-generic vmlinuz-5.15.0-117-generic initrd.img-5.19.0-46-generic vmlinuz-5.15.0-119-generic initrd.img-6.2.0-37-generic vmlinuz-5.19.0-46-generic initrd.img-6.5.0-44-generic vmlinuz-6.2.0-37-generic initrd.img-6.5.0-45-generic vmlinuz-6.5.0-44-generic initrd.img.old vmlinuz-6.5.0-45-generic lost+found vmlinuz.old
$ df /dev/nvme0n1p5 451320 427680 0 100% /boot
$ sudo dpkg --get-selections | grep linux-image linux-image-5.15.0-117-generic install linux-image-5.15.0-119-generic install linux-image-5.19.0-46-generic install linux-image-6.2.0-37-generic install linux-image-6.5.0-44-generic install linux-image-6.5.0-45-generic install linux-image-generic install linux-image-generic-hwe-22.04 install
initramfs modified to compress = xz
$ sudo apt autoremove Leyendo lista de paquetes... Hecho Creando árbol de dependencias... Hecho Leyendo la información de estado... Hecho Tal vez quiera ejecutar «apt --fix-broken install» para corregirlo. Los siguientes paquetes tienen dependencias incumplidas: linux-image-generic-hwe-22.04 : Depende: linux-image-6.8.0-40-generic pero no está instalado E: Dependencias incumplidas. Intente «apt --fix-broken install» sin paquetes (o especifique una solución).
$ sudo apt --fix-broken install .................................... dpkg: error al procesar el archivo /var/cache/apt/archives/linux-image-6.8.0-40- generic_6.8.0-40.40~22.04.3_amd64.deb (--unpack): no se pudieron copiar los datos extraídos de './boot/vmlinuz-6.8.0-40-generic' a '/boot/vmlinuz-6.8.0-40-generic.dpkg-new': fallo al escribir (No queda espacio en el dispositivo) No se escribió un informe «apport» porque el mensaje de error indica que el erro r es de disco lleno dpkg-deb: error: el subproceso copiado fue terminado por la s eñal (Tubería rota) Se encontraron errores al procesar: /var/cache/apt/archives/linux-image-6.8.0-40-generic_6.8.0-40.40~22.04.3_amd64. deb E: Sub-process /usr/bin/dpkg returned an error code (1)
$ LC_ALL=C sudo apt --fix-broken install
[sudo] password for celia: Reading package lists... Done Building dependency tree... Done Reading state information... Done Correcting dependencies... Done The following packages were automatically installed and are no longer required: linux-headers-5.15.0-117 linux-image-5.15.0-117-generic linux-modules-5.15.0-117-generic linux-modules-extra-5.15.0-117-generic Use 'sudo apt autoremove' to remove them. The following additional packages will be installed: linux-image-6.8.0-40-generic Suggested packages: fdutils linux-hwe-6.8-tools The following NEW packages will be installed: linux-image-6.8.0-40-generic 0 upgraded, 1 newly installed, 0 to remove and 109 not upgraded. 19 not fully installed or removed. Need to get 0 B/14.7 MB of archives. After this operation, 15.0 MB of additional disk space will be used. Do you want to continue? [Y/n] y (Reading database ... 472124 files and directories currently installed.) Preparing to unpack .../linux-image-6.8.0-40-generic_6.8.0-40.40~22.04.3_amd64.d eb ... Unpacking linux-image-6.8.0-40-generic (6.8.0-40.40~22.04.3) ... dpkg: error processing archive /var/cache/apt/archives/linux-image-6.8.0-40-gene ric_6.8.0-40.40~22.04.3_amd64.deb (--unpack): cannot copy extracted data for './boot/vmlinuz-6.8.0-40-generic' to '/boot/vmli nuz-6.8.0-40-generic.dpkg-new': failed to write (No space left on device) No apport report written because the error message indicates a disk full error dp kg-deb: error: paste subprocess was killed by signal (Broken pipe) Errors were encountered while processing: /var/cache/apt/archives/linux-image-6.8.0-40-generic_6.8.0-40.40~22.04.3_amd64. deb E: Sub-process /usr/bin/dpkg returned an error code (1)
