I'm using Ubuntu 12.04 and grub selections appear each time I boot. This happens on both of my computers.
I have tried editing the /etc/defaults/grub to use default, to use the 0 entry, and ran the update on it. But nothing seems to solve the problem.
(showing uncommented lines)
$ sudo nano /etc/default/grub
GRUB_DEFAULT=0
GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
$ sudo update-grub
Generating grub.cfg ...
Found linux image: /boot/vmlinuz-3.2.0-25-generic-pae
Found initrd image: /boot/initrd.img-3.2.0-25-generic-pae
Found linux image: /boot/vmlinuz-3.2.0-24-generic-pae
Found initrd image: /boot/initrd.img-3.2.0-24-generic-pae
Found memtest86+ image: /boot/memtest86+.bin
  No volume groups found
done
jokerdino
  • 41,732
Grub2 will boot straight into the default operating system if no other operating system is detected. No menu will be displayed. If another operating system is detected, the GRUB 2 menu will display.
But if the grub menu still displays, you may need to change the GRUB_TIMEOUT value from 10 to 0.
GRUB_TIMEOUT=10
to
GRUB_TIMEOUT=0
GRUB_TIMEOUT=value is the number of seconds before the default entry is automatically booted.
Peachy
  • 7,235
  • 40
  • 47
Open the terminal and run this command:
root@penreturns:~$ sudo gedit /etc/default/grub
Remove comment line (add "#"):
#GRUB_HIDDEN_TIMEOUT=0
It must look like this (by default)
Update your GRUB with this comand:
root@penreturns:~$ sudo update-grub
Reboot your system and you will see how the system will now stop at the GRUB2 boot screen.
Enjoy!
penreturns
  • 5,950
