This is follow up thread to: Failed update to 24.04
I tried finishing the update/upgrade, did full-upgrade and also dist-upgrade.
Was using ChatGPT to help me out navigate out of the mess I put myself into. Gave up and went to bed with my desktop up and running. Woke up to system booting only to terminal.
Right now I’m in dead spot. I don’t know what to do next and also ChatGPT sucks.
Outcome of —fix-broken install and —reinstall Ubuntu-desktop:
g g@gworkstation:~$ sudo apt --fix-broken install
A Reading package lists... Done a Building dependency tree... Done A Reading state information... Done
o 0 to upgrade, o to newly install, 0 to remove and 5 not to upgrade.
g g@gworkstation: ^$ sudo apt-get install --reinstall ubuntu-desktop i
Reading package lists... Done a Building dependency tree... Done Я Reading state information... Done
2 Some packages could not be installed. This may mean that you have
1 requested an impossible situation or if you are using the unstable b distribution that some required packages have not yet been created o or been moved out of Incoming.
T The following information may help to resolve the situation:
I The following packages have unmet dependencies.
1ibpipewire-0.3-0t64 : Depends: 1ibspa-0.2-modules (= 1.0.5-1ubuntu1) but 1.0.7-3 ubuntu22.04 is to be installed
3E: Unable to correct problems, you have held broken packages.
g gagworkstation: "$ sudo apt-get install --reinstall ubuntu-desktop
• Reading state information... Done
Some packages could not be installed. This may mean that you have 1 requested an impossible situation or if you are using the unstable b distribution that some required packages have not yet been created oor been moved out of Incoming.
T The following packages have unmet dependencies.
libpipewire-0.3-0t64 : Depends: 1ibspa-0.2-modules (= 1.0.5-1ubuntu1) but 1.0.7-3 ubuntu22.04 is to be installed
Outcome of sudo apt-get updated:
g@gworkstation:^$ sudo apt-get update Ign: 1 http://archive.ubuntu.com/ubuntu noble InRelease Ign:2 http://archive.ubuntu.com/ubuntu noble-updates InRelease Ign:3 https://brave-browser-apt-release.s3.brave.com stable InRelease Ign:4 https://repository.mullvad.net/deb/stable jammy InRelease Ign:5 http://archive.ubuntu.com/ubuntu noble-backports InRelease Ign:6 http://archive.ubuntu.com/ubuntu noble-security InRelease Ign: 1 http://archive.ubuntu.com/ubuntu noble InRelease Ign:2 http://archive.ubuntu.com/ubuntu noble-updates InRelease Ign:3 https://brave-browser-apt-release.s3.brave.com stable InRelease Ign:4 https://repository.mullvad.net/deb/stable jammy InRelease Ign:5 http://archive.ubuntu.com/ubuntu noble-backports InRelease Ign:6 http://archive.ubuntu.com/ubuntu noble-security InRelease Ign: 1 http://archive.ubuntu.com/ubuntu noble InRelease Ign:2 http://archive.ubuntu.com/ubuntu noble-updates InRelease Ign:3 https://brave-browser-apt-release.s3.brave.com stable InRelease Ign:4 https://repository.mullvad.net/deb/stable jammy InRelease Ign:5 http://archive.ubuntu.com/ubuntu noble-backports InRelease Ign:6 http://archive.ubuntu.com/ubuntu noble-security InRelease
3 Err:1 http://archive.ubuntu.com/ubuntu noble InRelease
Temporary failure resolving
*archive.ubuntu.com'
3 Err:2 http://archive.ubuntu.com/ubuntu noble-updates InRelease
"archive.ubuntu.com"
1 Err:3 https://brave-browser-apt-release.s3.brave.com stable InRelease
*brave-browser-apt-release.s3.brave.com'
3 Err:4 https://repository.mullvad.net/deb/stable jammy
InRelease
*repository.mullvad.net'
3 Err:5 http://archive.ubuntu.com/ubuntu noble-backports InRelease
Temporary failure resolving *archive.ubuntu.com"
3 Err:6 http://archive.ubuntu.com/ubuntu noble-security InRelease
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/noble/InRelease
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/noble-updates/InRelease
Release temporary rallure resolvive aunteubuntu. com
Temporary tallure resolving
W:
Failed to fetch http://archive.ubuntu.com/ubuntu/dists/noble-backports/InRelease
*archive.ubuntu.com*
W:
Failed to fetch http://archive.ubuntu.com/ubuntu/dists/noble-security/InRelease
W: Failed to fetch https://brave-browser-apt-release.s3.brave.com/dists/stable/InRelease
W: Failed to fetch https://repository.mullvad.net/deb/stable/dists/ jammy/InRelease
Temporary failure resolving repository.mullvad.net"
*brave-browser -apt-release.s3.brave.com'
W: Some index files failed to download. They have been ignored, or old ones used instead.
I reached the end of possible solutions I could come up on my own. Tried booting to grub recovery mode, shift does nothing, when I repeatedly press ESC I access grub command line. No gui or anything, so I didn’t proceed with worry I could mess up further. I would be thankful for any possible advice what to do next here in order to avoid losing access to files I have on my desktop.
