After I just ran update manager, suddenly my wifi options disappeared. Here is what i've gone through so far:
sudo lshw -class network
  *-network UNCLAIMED
       description: Network controller
       product: RTL8821CE 802.11ac PCIe Wireless Network Adapter
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:01:00.0
       version: 00
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress cap_list
       configuration: latency=0
       resources: ioport:3000(size=256) memory:80500000-8050ffff
lsusb Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 004: ID 04f3:2753 Elan Microelectronics Corp. Touchscreen Bus 001 Device 003: ID 0408:5365 Quanta Computer, Inc. HP TrueVision HD Camera Bus 001 Device 005: ID 0bda:b00a Realtek Semiconductor Corp. Realtek Bluetooth 4.2 Adapter Bus 001 Device 002: ID 046d:c52b Logitech, Inc. Unifying Receiver Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
lspci 00:00.0 Host bridge: Intel Corporation Ice Lake-LP Processor Host Bridge/DRAM Registers (rev 03) 00:02.0 VGA compatible controller: Intel Corporation Iris Plus Graphics G1 (Ice Lake) (rev 07) 00:04.0 Signal processing controller: Intel Corporation Device 8a03 (rev 03) 00:14.0 USB controller: Intel Corporation Ice Lake-LP USB 3.1 xHCI Host Controller (rev 30) 00:14.2 RAM memory: Intel Corporation Ice Lake-LP DRAM Controller (rev 30) 00:15.0 Serial bus controller: Intel Corporation Ice Lake-LP Serial IO I2C Controller #0 (rev 30) 00:15.1 Serial bus controller: Intel Corporation Ice Lake-LP Serial IO I2C Controller #1 (rev 30) 00:16.0 Communication controller: Intel Corporation Ice Lake-LP Management Engine (rev 30) 00:17.0 RAID bus controller: Intel Corporation 82801 Mobile SATA Controller [RAID mode] (rev 30) 00:1c.0 PCI bridge: Intel Corporation Device 34bf (rev 30) 00:1d.0 PCI bridge: Intel Corporation Ice Lake-LP PCI Express Root Port #9 (rev 30) 00:1f.0 ISA bridge: Intel Corporation Ice Lake-LP LPC Controller (rev 30) 00:1f.3 Audio device: Intel Corporation Ice Lake-LP Smart Sound Technology Audio Controller (rev 30) 00:1f.4 SMBus: Intel Corporation Ice Lake-LP SMBus Controller (rev 30) 00:1f.5 Serial bus controller: Intel Corporation Ice Lake-LP SPI Controller (rev 30) 01:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8821CE 802.11ac PCIe Wireless Network Adapter 02:00.0 Non-Volatile memory controller: Micron Technology Inc Device 5410 (rev 01)
rfkill list all 0: hci0: Bluetooth Soft blocked: no Hard blocked: no
sudo modprobe rtl8821ce && sudo dmesg | grep 8821 modprobe: FATAL: Module rtl8821ce not found in directory /lib/modules/6.8.0-40-generic
Previously, I had a similar problem, which is detailed in this thread
In that case, it was fixed with cd backport-iwlwifi && sudo make uninstall. However, that isn't working this time. It gives the error:
Generating local configuration database from kernel ...Kernel version parse failed!
make: *** [Makefile:42: uninstall] Error 1
We've now determined that the wifi works when booted to kernel 6.5 but fails when booted to 6.8. @jeremy31's suggestion gives (in 6.8):
lspci -nnk | grep -iA3 net
01:00.0 Network controller [0280]: Realtek Semiconductor Co., Ltd. RTL8821CE 802.11ac PCIe Wireless Network Adapter [10ec:c821]
    DeviceName: Realtek Wireless LAN + BT
    Subsystem: Hewlett-Packard Company RTL8821CE 802.11ac PCIe Wireless Network Adapter [103c:831a]
    Kernel modules: rtw88_8821ce
02:00.0 Non-Volatile memory controller [0108]: Micron Technology Inc Device [1344:5410] (rev 01)
    Subsystem: Micron Technology Inc Device [1344:0100]
You must have blacklisted the kernel module that is used in the 6.8 kernel and that rtl8821ce-dkms doesn't seem to work on that kernel. In terminal do
sudo sed -i 's/blacklist rtw88_8821ce/#blacklist rtw88_8821ce/' /etc/modprobe.d/blacklist.conf
Then reboot into the 6.8 kernel
Jeremy31
  • 13,293
