Running Ubuntu 20.04.
sudo virt-manager
Unable to connect to libvirt qemu:///system.
Verify that the 'libvirtd' daemon is running.
Googled ‘Verify that the 'libvirtd' daemon is running.’
https://ubuntuforums.org/showthread.php?t=2480264 mentions KVM.
kvm --version
QEMU emulator version 8.0.4 (Debian 1:8.0.4+dfsg-1ubuntu3.23.10.5~backport20.04.202407120432~ubuntu20.04.1) Copyright (c) 2003-2022 Fabrice Bellard and the QEMU Project developers
sudo systemctl start libvirtd
Failed to start libvirtd.service: Unit libvirtd.service is masked.
systemctl status libvirtd
● libvirtd.service Loaded: masked (Reason: Unit libvirtd.service is masked.) Active: inactive (dead)
sudo systemctl unmask libvirtd.service
Removed /etc/systemd/system/libvirtd.service.
sudo systemctl status libvirtd.service
Unit libvirtd.service could not be found.
sudo apt install qemu-kvm libvirt-daemon-system
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies. libvirt-daemon-system : Depends: libvirt-clients (= 6.0.0-0ubuntu8.20) but 10.0.0-2ubuntu8.3~backport20.04.202408270202~ubuntu20.04.1 is to be installed Depends: libvirt-daemon (= 6.0.0-0ubuntu8.20) but it is not going to be installed qemu-kvm : Depends: qemu-system-x86 (= 1:4.2-3ubuntu6.29) but 1:8.0.4+dfsg-1ubuntu3.23.10.5~backport20.04.202407120432~ubuntu20.04.1 is to be installed E: Unable to correct problems, you have held broken packages.
sudo apt-get install libvirt-clients
libvirt-clients is already the newest version (10.0.0-2ubuntu8.3~backport20.04.202408270202~ubuntu20.04.1).
0 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
sudo apt-get install libvirt-daemon
libvirt-daemon is already the newest version (10.0.0-2ubuntu8.3~backport20.04.202408270202~ubuntu20.04.1).
Unsure how to fix broken packages.
Thank you.
sudo synaptic
Highlight All
Edit -> Fix Broken Packages
Clicked Reload
0 broken appears at bottom of window.
So, same issue.
