When I insert the USB, it does not appear in the devices list in Files.
Its properties are, as per Disks App:
- model: USB Disk 3.0 (1100)
- device: /dev/sda1
- partitioning: Master Boot Record
- partition type: W95 FAT32 (LBA)
- content: unknown
I need to read it in order to put in in my Wii games.
Years ago I used qwbfsmanager but it is no more available (I already tried on Windows 10 Pro but with more issues...).
I already installed wiithon but at launch it does nothing, if I launch it from terminal this output occurs:
Traceback (most recent call last):
File "/usr/games/wiithon", line 138, in <module>
App()
File "/usr/games/wiithon", line 48, in App
prefs.cargarPreferenciasPorDefecto()
File "/usr/share/wiithon/preferencias.py", line 53, in cargarPreferenciasPorDefecto
self.iniciarPreferencia('string', 'device_seleccionado')
File "/usr/share/wiithon/preferencias.py", line 283, in iniciarPreferencia
preferencia = session.query(Preferencia).filter(sql).first()
File "<string>", line 2, in filter
File "/usr/lib/python2.7/dist-packages/sqlalchemy/orm/base.py", line 220, in generate
fn(self, *args[1:], **kw)
File "/usr/lib/python2.7/dist-packages/sqlalchemy/orm/query.py", line 1789, in filter
criterion = expression._expression_literal_as_text(criterion)
File "/usr/lib/python2.7/dist-packages/sqlalchemy/sql/elements.py", line 4556, in _expression_literal_as_text
return _literal_as_text(element)
File "/usr/lib/python2.7/dist-packages/sqlalchemy/sql/elements.py", line 4579, in _literal_as_text
return _literal_as(element, _no_text_coercion)
File "/usr/lib/python2.7/dist-packages/sqlalchemy/sql/elements.py", line 4565, in _literal_as
return text_fallback(element)
File "/usr/lib/python2.7/dist-packages/sqlalchemy/sql/elements.py", line 4609, in _no_text_coercion
"extra": "%s " % extra if extra else "",
sqlalchemy.exc.ArgumentError: Textual SQL expression u"preferencias.campo=='devi..." should be explicitly declared as text(u"preferencias.campo=='devi...")
There is a way to read it or a program to handle Wii (wbfs) files on Ubuntu?
I'm using Ubuntu 20.04 and Ubuntu 22.04 (on different machines) and unfortunately I cannot upgrade to the latest one.
Thanks
