user@notebook:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 24.04.1 LTS
Release: 24.04
Codename: noble
user@notebook:~$ sudo apt remove python3.12
Reading package lists... Done
Building dependency tree... Done
python3 : Depends: python3.12 (>= 3.12.3-0~) but it is not going to be installed
shim-signed : Depends: grub-efi-amd64-signed (>= 1.191~) but it is not going to be installed or
grub-efi-arm64-signed (>= 1.191~) but it is not installable or
base-files (< 12.3) but 13ubuntu10.1 is to be installed
Depends: grub-efi-amd64-signed (>= 1.187.2~) but it is not going to be installed or
grub-efi-arm64-signed (>= 1.187.2~) but it is not installable
Depends: grub2-common (>= 2.04-1ubuntu24) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Asked
Active
Viewed 1,404 times
