I wanted to install npm in Ubuntu 22.04.4 LTS. I tried this command sudo apt install npm , but I got this result:
Reading package lists... Done Building dependency tree... Done Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
The following packages have unmet dependencies: npm : Depends: node-agent-base but it is not going to be installed Depends: node-aproba but it is not going to be installed Depends: node-archy but it is not going to be installed Depends: node-cacache but it is not going to be installed Depends: node-chalk but it is not going to be installed Depends: node-cli-table3 Depends: node-colors but it is not going to be installed Depends: node-columnify but it is not going to be installed Depends: node-debug but it is not going to be installed Depends: node-emoji-regex Depends: node-got but it is not going to be installed Depends: node-graceful-fs but it is not going to be installed Depends: node-gyp but it is not going to be installed Depends: node-https-proxy-agent but it is not going to be installed Depends: node-mkdirp but it is not going to be installed Depends: node-ms but it is not going to be installed Depends: node-nopt but it is not going to be installed Depends: node-normalize-package-data but it is not going to be installed Depends: node-npm-package-arg but it is not going to be installed Depends: node-npmlog but it is not going to be installed Depends: node-read-package-json but it is not going to be installed Depends: node-rimraf but it is not going to be installed Depends: node-semver but it is not going to be installed Depends: node-ssri but it is not going to be installed Depends: node-string-width but it is not going to be installed Depends: node-strip-ansi but it is not going to be installed Depends: node-tar but it is not going to be installed Depends: node-validate-npm-package-name but it is not going to be installed Depends: node-which but it is not going to be installed Depends: node-write-file-atomic but it is not going to be installed Depends: nodejs:any (>= 10) Recommends: node-tap but it is not going to be installed E: Unable to correct problems, you have held broken packages.
Can you help me please, thank you.
