I am using Ubuntu 20.04 LTS on an AWS server. I am trying to get geoblacklight installed, but it hasn't been updated in the past decade and I have been running into many issues. This is my first time using Linux in some years and I don't remember much at all. Here is the original script for installation (originally for use with vagrant):
wget -qO- https://apt.boundlessgeo.com/gpg.key | apt-key add -
echo "deb https://apt.boundlessgeo.com/suite/v46/ubuntu/ trusty main" > /etc/apt/sources.list.d/opengeo.list
apt-get update
apt-cache search opengeo
apt-get -y install opengeo-server
This gave me a deprecation error, so I looked up some solutions and replaced the first line of the script with wget -qO- https://apt.boundlessgeo.com/gpg.key | sudo tee /etc/apt/trusted.gpg.d/gpg.key which didn't give an error until I called apt-get update where it gave the following output:
Hit:1 http://us-east-1.ec2.archive.ubuntu.com/ubuntu noble InRelease
Get:2 http://us-east-1.ec2.archive.ubuntu.com/ubuntu noble-updates InRelease [126 kB]
Hit:3 http://us-east-1.ec2.archive.ubuntu.com/ubuntu noble-backports InRelease
Get:4 http://security.ubuntu.com/ubuntu noble-security InRelease [126 kB]
Ign:5 https://apt.boundlessgeo.com/suite/v46/ubuntu trusty InRelease
Get:6 http://security.ubuntu.com/ubuntu noble-security/main amd64 Packages [293 kB]
Get:7 http://security.ubuntu.com/ubuntu noble-security/universe amd64 Packages [250 kB]
Hit:8 https://ppa.launchpadcontent.net/openjdk-r/ppa/ubuntu noble InRelease
Err:5 https://apt.boundlessgeo.com/suite/v46/ubuntu trusty InRelease
Temporary failure resolving 'apt.boundlessgeo.com'
Fetched 796 kB in 7s (106 kB/s)
Reading package lists... Done
W: Failed to fetch https://apt.boundlessgeo.com/suite/v46/ubuntu/dists/trusty/InRelease Temporary failure resolving 'apt.boundlessgeo.com'
W: Some index files failed to download. They have been ignored, or old ones used instead.
I also tried wget -qO- https://apt.boundlessgeo.com/gpg.key | sudo tee /etc/apt/keyrings/gpg.key as suggested by the article I found, but this did not fix the issue.
I also tried echo "nameserver 8.8.8.8" | sudo tee /etc/resolv.conf > /dev/null to see if it was a DNS issue, to no avail. Should I permanently change my DNS? Is there something else going on here? Is the repo even still available, and how come I was able to get the original script to work in Ubuntu 16.04.3 with vagrant if so?
Note: it is also possible that the vagrant script didn't work and I completely missed it, but I doubt that this was the case since all of the other build issues from the other scripts---such as bundler and ruby being too outdated to install---caused fatal errors that canceled the entire build.
I imagine that something similar would've happened with geoblacklight, but I could be wrong. By the way, I did all of this with root and tried with sudo before each command as well, in case that is important to mention.
