Ubuntu was booting up fine yesterday but now when I try to boot it up I just end up with these lines of code:
[ 0.120687] x86/cpu: SGX disabled by BIOS.
[ 3.746475] nvme nvme0: failed to set APST feature (2)
[ 5.045628] nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
[ 5.045681] ucsi_ccg 0-0008: i2c_transfer failed -110
[ 5.045717] ucsi_ccg 0-0008: ucsi_ccg_init failed - -110
/dev/nvme0n1p6: recovering journal
/dev/nvme0n1p6: clean, 224714/1001712 files, 3811938/4000000 blocks
[ 7.105159]
I'm a total noob at this so I have no idea what any of this means. I saw another thread saying that it has to do with an issue with Nvidia USB-C's or something and one of the recommended fixes was to "create a /etc/modprobe.d/blacklist_i2c-nvidia-gpu.conf with these contents: blacklist i2c_nvidia_gpu."
I'm not sure how I would even go about doing that without being able to open up the linux terminal, let alone boot it up. Do I need to open linux in recovery mode in order to create this config? What option would I select to type this all out?
Also there were two versions of linux in the advanced settings but I still get this same exact error with either versions. And if there's a technical support hotline for ubuntu, that would be greatly appreciated.
EDIT: I have the Ubuntu 22.04.4 LTS (Jammy Jellyfish) release as recommended by "The Odin Project" for dual-booting. In the grub menu it also says I can either boot up "Ubuntu, with Linux 6.5.0-45-generic" or "Ubuntu, with Linux 6.5.0-18-generic" with recovery mode options available for both versions.
