Newbie here, trying to reinstall the default ubuntu boot logo after trying out kubuntu-desktop and then removing it. The bootscreen didnt revert. When I run sudo update-alternatives --config default.plymouth the options are:
0 /usr/share/plymouth/themes/bgrt/bgrt.plymouth 110
auto mode
1 /usr/share/plymouth/themes/bgrt/bgrt.plymouth 110
manual mode
2 /usr/share/plymouth/themes/ubuntu-text/ubuntu-text.plymouth 100
manual mode
ubuntu-logo just doesnt exist.
This is what i get if I run sudo apt install plymouth-theme-ubuntu-logo and if I try to install those packages it just says theyre already installed
~$ sudo apt-get install plymouth-theme-ubuntu-logo
Reading package lists... Done
Building dependency tree... Done
plymouth-theme-ubuntu-logo : Depends: plymouth (= 0.9.3-1ubuntu7) but
24.004.60-1ubuntu7 is to be installed
Depends: plymouth-label (= 0.9.3-1ubuntu7) but
Currently I have the theme with the "Ubuntu 24.04" text with 4 dots underneath
