I have used checkinstall in Ubuntu 18.04, and 16.04, however in 24.04 I it seems no longer work as expected. Here is a step by step description (but you need a recent emacs version installed)
clone the auctex package via git clone git://git.savannah.gnu.org/auctex.git
switch to the master branch via git switch --guess master
run
./autogen.sh
run ./configure --with-emacs=/opt/emacs29/bin/emacs --prefix=$HOME/ALLES/ --with-lispdir=$HOME/emacs/site-lisp/packages/auctex-git --without-texmf-dir
make
make install
that works however
checkinstall or checkinstall make install return the following error.
/usr/bin/install -c -m 644 preview.sty /home/oub/emacs/site-lisp/packages/auctex-git/auctex/latex
/usr/bin/install: cannot create regular file '/home/oub/emacs/site-lisp/packages/auctex-git/auctex/latex': No such file or directory
make[1]: *** [Makefile:53: install-texmf] Error 1
make[1]: Leaving directory '/home/oub/tmp/auctex/latex'
make: *** [Makefile:324: install-texmf] Error 2
**** Installation failed. Aborting package creation.
Cleaning up...OK
Bye.
Any idea who is the culprit here? There is a github page https://github.com/ruxkor/checkinstall but the last commit is 16 years ago, the issues are not answered. That is why I post it here. regards
Uwe Brauer
Recently, I had the same issue after upgrading to 24.04. The fix is rather easy, only adding --fstrans=no to the checkinstall call solved it for me, i.e. sudo checkinstall --fstrans=no should work.
Gibtnix
