I'm using Ubuntu 24.04 and VMware Workstation 17.5.2 and the 3D Accelerated Graphics options does not work on the host. Whichever VM I try, whichever OS I try to load, I get the error message "No 3D support is available from the host."
This is my processor/graphics: AMD Ryzen™ 7 PRO 4750U with Radeon™ Graphics × 16
I am using the latest AMD drivers from repo.radeon.com
I've also installed the mesa-2404 drivers from the App Center.
I followed the instructions here: https://docs.vmware.com/en/VMware-Workstation-Pro/17/com.vmware.ws.using.doc/GUID-EA588485-718A-4FD8-81F5-B6E1F04C5788.html
glxinfo | grep direct
direct rendering: Yes
    GL_AMD_gpu_shader_int64, GL_AMD_multi_draw_indirect,
    GL_ARB_depth_clamp, GL_ARB_derivative_control, GL_ARB_direct_state_access,
    GL_ARB_draw_elements_base_vertex, GL_ARB_draw_indirect,
    GL_ARB_indirect_parameters, GL_ARB_instanced_arrays,
    GL_ARB_map_buffer_range, GL_ARB_multi_bind, GL_ARB_multi_draw_indirect,
    GL_AMD_multi_draw_indirect, GL_AMD_performance_monitor,
    GL_ARB_direct_state_access, GL_ARB_draw_buffers,
    GL_ARB_draw_indirect, GL_ARB_draw_instanced, GL_ARB_enhanced_layouts,
    GL_EXT_direct_state_access, GL_EXT_draw_buffers2, GL_EXT_draw_instanced,
This used to work previously on this same machine, I believe it was on Ubuntu 22.04.
Thank you!
Vince
  • 17
I found the solution with Chat GPT!
sudo nano /etc/vmware/config
Add these two lines:
mks.gl.allowBlacklistedDrivers = "TRUE"
mks.enable3d = "TRUE"
3D accelerated now, hopefully this will help someone.
Vince
  • 17
