I am accustomed to offline wiki browsing. I thought it would be great if I can read Ubuntu wiki in the same way.
Is there anyway I can read Ubuntu Wiki offline? Help will be much appreciated if I can download Wiki dumps to my computer much like in the case of Wikipedia.
I already tried suggestions given in this question How can I download archive of ubuntu community documentation so that i can use it offline?, but using the
wget -p --convert-links -r https://wiki.ubuntu.com -o logfile
gives me HTML files that are a real pain to browse when offline.
Please suggest me some other way to do this.
How to Browse Ubuntu-Wiki Offline
1. Save current page
In case you only need to save the current page simply use the save page as function in your browser.
Another way is to use the pocket function of your browser. Look at your browser manual or search for an extension.
2. wget
Using wget is another option
wget --recursive --no-clobber --page-requisites 7--html-extension \
     --convert-links --restrict-file-names=windows --domains website.org \
     --no-parent \
     www.yourwebsite.to.save
3. WebHTTrack Website Copier
Description: Copy websites to your computer, httrack with a Web interface WebHTTrack is an offline browser utility, allowing you to download a World Wide website from the Internet to a local directory, building recursively all directories, getting html, images, and other files from the server to your computer, using a step-by-step web interface.
Install it with
sudo apt-get install webhttrack
A good description of the functionality can be found on this link.
abu_bua
  • 11,313
I searched around a bit and wasn't able to find anything similar to Mediawiki's Dump You may want to try using webchecker.py
TrinitronX
  • 3,394
From the second answer from How can I download archive of ubuntu community documentation so that i can use it offline?
One simple way of doing this is when you are on your chosen a page in the community documentation website just select Print, then Print to File and save it as a PDF in your home folder
