Overview
I can't install wine32 on my OS:
aydin@kdeneon:~$ uname -a
Linux kdeneon 6.5.0-41-generic #41~22.04.2-Ubuntu SMP PREEMPT_DYNAMIC x86_64 x86_64 x86_64 GNU/Linux
Things I tried
1.
When I try to install it using apt:
aydin@kdeneon:~$ sudo apt install wine32
Reading package lists... Done
Building dependency tree... Done
Starting pkgProblemResolver with broken count: 1
Starting 2 pkgProblemResolver with broken count: 1
Investigating (0) libfaudio0:i386 < none -> 22.02-1 @un puN Ib >
Broken libfaudio0:i386 Depends on libsdl2-2.0-0:i386 < none | 2.0.20+dfsg-2ubuntu1.22.04.1 @un uH > (>= 2.0.16)
Considering libsdl2-2.0-0:i386 1 as a solution to libfaudio0:i386 0
Done
libfaudio0:i386 : Depends: libsdl2-2.0-0:i386 (>= 2.0.16) but it is not going to be installed
2.
I did some research and have tried to install it using aptitude but it did not go well thus I aborted it:
aydin@kdeneon:~$ sudo aptitude install wine32:i386
The following NEW packages will be installed:
wine32:i386{b}
The following packages will be REMOVED:
acl{u} gstreamer1.0-plugins-base:i386{u} hplip-data{u} libapparmor1:i386{u} libasound2:i386{u} libasound2-plugins:i386{u} libasyncns0:i386{u} libatomic1:i386{u} libavahi-client3:i386{u} libavahi-common-data:i386{u}
libavahi-common3:i386{u} libcapi20-3:i386{u} libcdparanoia0:i386{u} libcups2:i386{u} libcurl3-gnutls:i386{u} libcurl4:i386{u} libdbus-1-3:i386{u} libdrm2:i386{u} libdw1:i386{u} libedit2:i386{u} libelf1:i386{u} libexif12:i386{u}
libflac8:i386{u} libgd3:i386{u} libgdbm-compat4:i386{u} libgdbm6:i386{u} libglapi-mesa:i386{u} libglu1-mesa:i386{u} libglvnd0:i386{u} libgnutls30:i386{u} libgphoto2-6:i386{u} libgphoto2-port12:i386{u} libgsm1:i386{u}
libgstreamer-plugins-base1.0-0:i386{u} libgstreamer1.0-0:i386{u} libhogweed6:i386{u} libhpmud0{u} libicu70:i386{u} libieee1284-3{u} libieee1284-3:i386{u} libimagequant0{u} libjack-jackd2-0:i386{u} libldap-2.5-0:i386{u}
libllvm15:i386{u} libltdl7:i386{u} libnettle8:i386{u} libnghttp2-14:i386{u} libodbc2:i386{u} libogg0:i386{u} libopengl0:i386{u} libopus0:i386{u} liborc-0.4-0:i386{u} libosmesa6:i386{u} libp11-kit0:i386{u} libpcap0.8:i386{u}
libpci3:i386{u} libperl5.34:i386{u} libpsl5:i386{u} libpulse0:i386{u} libraqm0{u} librtmp1:i386{u} libsamplerate0:i386{u} libsane-common{u} libsane-hpaio{u} libsane1:i386{u} libsasl2-2:i386{u} libsasl2-modules:i386{u}
libsasl2-modules-db:i386{u} libsensors5:i386{u} libsndfile1:i386{u} libsnmp-base{u} libsnmp40{u} libsnmp40:i386{u} libssh-4:i386{u} libtasn1-6:i386{u} libtheora0:i386{u} libunwind8:i386{u} libusb-1.0-0:i386{u} libv4l-0:i386{u}
libv4lconvert0:i386{u} libvisual-0.4-0:i386{u} libvorbis0a:i386{u} libvorbisenc2:i386{u} libwayland-client0:i386{u} libwrap0:i386{u} libx11-xcb1:i386{u} libxcomposite1:i386{u} libxcursor1:i386{u} libxfixes3:i386{u} libxi6:i386{u}
libxinerama1:i386{u} libxkbcommon0:i386{u} libxkbregistry0:i386{u} libxml2:i386{u} libxpm4:i386{u} libxrandr2:i386{u} libxslt1.1:i386{u} libxxf86vm1:i386{u} ocl-icd-libopencl1:i386{u} printer-driver-hpcups{u}
printer-driver-postscript-hp{u} python3-olefile{u} python3-pexpect{u} python3-pil{u} python3-ptyprocess{u} python3-renderpm{u} python3-reportlab{u} python3-reportlab-accel{u} sane-airscan{u} sane-utils:i386{u} wine-stable:i386{u}
wine-stable-i386:i386{u}
0 packages upgraded, 1 newly installed, 112 to remove and 13 not upgraded.
Need to get 229 kB of archives. After unpacking 927 MB will be freed.
wine32:i386 : Depends: libwine:i386 (= 6.0.3~repack-1) but it is not installable
The following actions will resolve these dependencies:
Remove the following packages:
libjpeg-turbo8:i386 [2.1.5-2+22.04+jammy+release+build13 (jammy, now)]
libjpeg8:i386 [8c-2ubuntu10 (jammy, now)]
libpoppler-glib8:i386 [22.02.0-2ubuntu0.4 (jammy-updates, now)]
libpoppler118:i386 [22.02.0-2ubuntu0.4 (jammy-updates, now)]
libtiff5:i386 [4.3.0-6ubuntu0.9 (jammy-security, jammy-updates, now)]
Keep the following packages at their current version:
wine32:i386 [Not Installed]
Accept this solution? [Y/n/q/?] n
3.
I also tried to fix packages using sudo apt --fix-broken install which didn't help.
How you can answer
The best way you can answer is to give an answer to these questions:
- Is it recommended to install it using
aptitudeattentive to what it will remove? - Is there another way that I could install it?
- Can I fix the issue with either of the ways I tried?
