I would like to change the refresh rate of the laptop display(main monitor) as it has continuous flickering and intermittent white lines and the only options are 60.08Hz or 144.03Hz(like on Windows 11).
By doing some tests on Windows 11 using CRU I managed to significantly reduce these effects by setting the refresh rate to 120Hz.
Searching around I found somewhat dated answers and before doing any damage I preferred to ask you. Thanks in advance to anyone who will respond.
WAYLAND1 is the laptop display.
This is xrandr output:
Screen 0: minimum 16 x 16, current 2688 x 900, maximum 32767 x 32767
XWAYLAND0 connected 1152x720+0+180 (normal left inverted right x axis y axis) 410mm x 260mm
1152x720 59.75*+
800x600 59.47
640x480 59.38
320x240 59.52
720x480 59.71
640x400 59.20
320x200 58.96
1024x576 59.58
864x486 59.45
720x400 59.55
640x350 58.91
XWAYLAND1 connected primary 1536x864+1152+0 (normal left inverted right x axis y axis) 340mm x 190mm
1536x864 143.88*+
1152x864 143.92
1024x768 143.87
800x600 143.83
640x480 143.85
320x240 142.05
1280x800 143.84
720x480 143.85
640x400 143.37
320x200 141.40
1368x768 143.77
1280x720 143.85
1024x576 143.91
864x486 143.63
720x400 143.88
640x350 143.57
