I am currently using Kubuntu 22.04.
I want to install poppler which I need for using the yazi CLI file manager, but I have a problem working with tarball files and getting a build from them, I downloaded the poppler-24.06.1.tar.xz file and poppler-data-0.4.12.tar.gz from: https://poppler.freedesktop.org/
I tried:
tar -xf poppler-data-0.4.12.tar.gz
cd poppler-data-0.4.12
sudo make install
cd ..
after that:
tar -xf poppler-24.06.1.tar.xz
cd poppler-24.06.1
./configure
But when I get to the step that I need to enter:
./configure
This message occurs:
bash: ./configure: No such file or directory
There is no such folder as 'configure'
I want to install poppler, but I don't know how.
Update:
I follow the instructions of basic installation inside the INSTALL:
mkdir build
cd build
cmake ..
then this error occurred:
-- The C compiler identification is GNU 11.4.0
-- The CXX compiler identification is GNU 11.4.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Performing Test GCC_HAS_AS_NEEDED
-- Performing Test GCC_HAS_AS_NEEDED - Success
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.29.2")
-- Checking _FILE_OFFSET_BITS for large files
-- Checking _FILE_OFFSET_BITS for large files - not needed
CMake Warning at CMakeLists.txt:98 (message):
No test data found in $testdatadir.
You will not be able to run 'make test' successfully.
The test data is not included in the source packages
and is also not part of the main git repository. Instead,
you can checkout the test data from its own git
repository with:
git clone git://git.freedesktop.org/git/poppler/test
You should checkout the test data as a sibling of your
poppler source folder or specify the location of your
checkout with -DTESTDATADIR=/path/to/checkoutdir/test.
-- Found Freetype: /usr/lib/x86_64-linux-gnu/libfreetype.so (found suitable version "2.11.1", minimum required is "2.11")
-- Found Fontconfig: /usr/lib/x86_64-linux-gnu/libfontconfig.so (found suitable version "2.13.1", minimum required is "2.13")
-- Checking for module 'nss>=3.68'
-- No package 'nss' found
-- Could NOT find NSS3 (missing: NSS3_LIBRARIES NSS3_CFLAGS) (Required is at least version "3.68")
CMake Error at CMakeLists.txt:162 (MESSAGE):
Could not find the 3.68 version of NSS3. If you're not interested in the
features it provides set the cmake ENABLE_NSS3 option to OFF
Call Stack (most recent call first):
CMakeLists.txt:167 (find_soft_mandatory_package)
-- Configuring incomplete, errors occurred!
See also "/home/glados/Downloads/Persepolis/Others/poppler-24.06.1/build/CMakeFiles/CMakeOutput.log".
