22
I use locate all the time to find files that I know the name of, locate is very fast and I love that. For recently created files find is great, normally with recently created files I know where basically they were created so I don't have to search my entire file system.
When I've forgotten the location of a directory however neither find nor locate seem ideal.
Locate always spits out far too much information because every file within a directory is also a match for locate. For instance if I was searching for a directory named log somewhere on my file system locate log would return tons and tons of results. If I do the same thing with find, find / -name log -type d find takes minutes to run and spits out all sorts of permissions errors every time it encounters a folder it can't read.
Is there a better way?
Answer: So I'm sticking with grep until I find something else:
locatedir () {
    for last; do true; done
    if [[ $last == *\/* ]]
    then
        locate $@ | grep "${last}\$"
    else
        locate $@ | grep "/${last}\$"
    fi
Michael
  • 323
You can use the option --regex (-r) of locate:
locate -r '/log$'
Volker Siegel
  • 13,295
12
A way (I suspect there may be a better way) is to use grep to return only the those paths which end in your folder name :
locate foldername | grep /foldername$
misterben
  • 7,437
Have you tried:
locate /home/insertusernamehere/*/filename?
or
locate file | grep -i '^/home/.*/examplesubdirectory'?
or any variation of such?
RolandiXor
  • 51,797
Here it is
locatedir () {
    locate "$*" | while read line
    do
    if [ -d "$line" ] ; then echo $line ; fi
    done
locatedir $*
