I'm on a corporate laptop dual booted with Ubuntu and Windows. Whenever I try to install things like Caddy, Docker Desktop, or really any application it turns into a whole thing and I can't install them. I'm also new to Linux so I don't understand the seemingly arbitrary strings of numbers and letters that represent files(?) in Ubuntu.
I've attempted to clear my caches, re-install certificates, use gpt instead of apt-key (apparently it's deprecated but still defaults to it?), etc. When I try to run 'apt update', any non-standard applications are ignored and I get errors back.
Edit: Here's the error I get for step one, doing an apt-get update
Ign:2 https://download.docker.com/linux/ubuntu jammy InRelease
Err:2 https://download.docker.com/linux/ubuntu jammy InRelease
  Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 146.112.250.208 443]
Fetched 2,054 kB in 8s (267 kB/s)
Reading package lists... Done
W: Failed to fetch https://download.docker.com/linux/ubuntu/dists/jammy/InRelease  Certificate verification failed: The certificate is NOT trusted. The certificate issuer is unknown.  Could not handshake: Error in the certificate verification. [IP: 146.112.250.208 443]
W: Some index files failed to download. They have been ignored, or old ones used instead.
openssl s_client -connect download.docker.com:443 response:
CONNECTED(00000003)
depth=2 C = US, ST = California, L = San Francisco, O = Cisco, CN = Cisco Umbrella Primary SubCA
verify error:num=20:unable to get local issuer certificate
verify return:1
depth=1 O = Cisco, CN = Cisco Umbrella Secondary SubCA nyc-SG
verify return:1
depth=0 C = US, ST = California, L = San Francisco, O = "Cisco Systems, Inc.", CN = download.docker.com
verify return:1
Certificate chain
 0 s:C = US, ST = California, L = San Francisco, O = "Cisco Systems, Inc.", CN = download.docker.com
   i:O = Cisco, CN = Cisco Umbrella Secondary SubCA nyc-SG
   a:PKEY: rsaEncryption, 2048 (bit); sigalg: RSA-SHA256
   v:NotBefore: Jun 16 11:33:13 2024 GMT; NotAfter: Jun 21 11:33:13 2024 GMT
 1 s:O = Cisco, CN = Cisco Umbrella Secondary SubCA nyc-SG
   i:C = US, ST = California, L = San Francisco, O = Cisco, CN = Cisco Umbrella Primary SubCA
   v:NotBefore: Jun 16 19:01:12 2024 GMT; NotAfter: Jun 27 19:01:12 2024 GMT
 2 s:C = US, ST = California, L = San Francisco, O = Cisco, CN = Cisco Umbrella Primary SubCA
   i:O = Cisco, CN = Cisco Umbrella Root CA
   v:NotBefore: May 14 18:21:48 2024 GMT; NotAfter: May 14 18:21:48 2029 GMT
Server certificate
-----BEGIN CERTIFICATE-----
[SERVER CERTIFICATE REMOVED]
-----END CERTIFICATE-----
subject=C = US, ST = California, L = San Francisco, O = "Cisco Systems, Inc.", CN = download.docker.com
issuer=O = Cisco, CN = Cisco Umbrella Secondary SubCA nyc-SG
No client certificate CA names sent
Peer signing digest: SHA256
Peer signature type: RSA-PSS
Server Temp Key: X25519, 253 bits
SSL handshake has read 3724 bytes and written 401 bytes
Verification error: unable to get local issuer certificate
New, TLSv1.3, Cipher is TLS_AES_256_GCM_SHA384
Server public key is 2048 bit
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
Verify return code: 20 (unable to get local issuer certificate)
Post-Handshake New Session Ticket arrived:
SSL-Session:
    Protocol  : TLSv1.3
    Cipher    : TLS_AES_256_GCM_SHA384
    Session-ID: [SESSION-ID-REMOVED]
    Session-ID-ctx:
    Resumption PSK: [PSK-REMOVED]
    PSK identity: None
    PSK identity hint: None
    SRP username: None
    TLS session ticket lifetime hint: 7200 (seconds)
    TLS session ticket:
    [TLS-SESSION-TICKET-REMOVED]
    Start Time: 1718807630
    Timeout   : 7200 (sec)
    Extended master secret: no
    Max Early Data: 0
read R BLOCK
SSL-Session:
    Protocol  : TLSv1.3
    Session-ID-ctx:
    PSK identity: None
    SRP username: None
    TLS session ticket:
    Max Early Data: 0
read R BLOCK
Aibaahl
  • 101
