I am a novice at Ubuntu and unfortunately i have deleted 3 files in the usr/bin folder
python 2.7
python
python 2.6
Now my update manager wont work and when i type in python into gnome it says that it is no longer there.
Please help me ive tried loads of different things but it just wont work.
The closest i got was the following:
I typed in sudo apt-get -f install
and i thought i had fixed it but then i got a error message -
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
  gir1.2-folks-0.6 gir1.2-polkit-1.0 libcogl5 mutter-common gir1.2-json-1.0
  libcaribou0 gir1.2-accountsservice-1.0 gir1.2-clutter-1.0 gir1.2-gkbd-3.0
  gir1.2-networkmanager-1.0 caribou libcogl-common libmutter0
  gir1.2-mutter-3.0 gjs gir1.2-caribou-1.0 libclutter-1.0-0
  gir1.2-telepathylogger-0.2 libclutter-1.0-common cups-pk-helper
  gir1.2-upowerglib-1.0 gir1.2-cogl-1.0 libmozjs185-1.0
  gir1.2-telepathyglib-0.12 gir1.2-gee-1.0 libgjs0c gnome-shell-common
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
  ubuntu-sso-client
The following packages will be upgraded:
  ubuntu-sso-client
1 upgraded, 0 newly installed, 0 to remove and 35 not upgraded.
2 not fully installed or removed.
Need to get 0 B/57.7 kB of archives.
After this operation, 16.4 kB of additional disk space will be used.
Do you want to continue [Y/n]? y
Setting up python-minimal (2.7.2-7ubuntu2) ...
/var/lib/dpkg/info/python-minimal.postinst: 4: python2.7: not found
dpkg: error processing python-minimal (--configure):
 subprocess installed post-installation script returned error exit status 127
 python-minimal
any advice is appreciated!
Simula
  • 81
I would suggest trying to run the live CD, find those files you deleted, and copy them to your installed /usr/bin folder. This should not be too hard to do. You can probably mount your installed partition using Nautilus, open it, and try copying using the GUI. If there is an error due to permissions, you may need to use the terminal to copy the files to (I believe) /media/*/usr/bin using "sudo cp", where the asterisk will be the name of the partition for your installation.
As a novice, you should not be deleting files that require root/admin authority (ie, using sudo or equivalent) without either knowing absolutely that it's OK, or at least copying it to a temporary folder for a while to make sure it's OK. That is why only certain users are allowed to do that.
Edit: More details
I booted my live CD (12.04), and I do see python 2.7 in the directory you specified. I don't think you need the previous version.
Using Nautilus, I was able to click on my real installation, and it automounted to /media, as expected. The files in /media/usr/bin are owned by root, so nautilus can't copy the files, unless it's run as root.
To reproduce the files, do this:
  1. Make sure your installation is mounted by clicking on it in Nautilus, where you should then see the symbol for mounted partitions, a sort of up-arrow with a line under it.
  2. Run the bash terminal to get a command line, and enter cd /media/*/usr/bin, where the asterisk is the name you see in Nautilus; you can press tab to autocomplete so you don't need to type in the name.
  3. Enter the command sudo cp -P /usr/bin/py* ., which will copy the python files to the current directory, and preserve the links (python links to python2.7).
This should replace the deleted files.
You might be able to reinstall it using the software center or apt-get if you were to reinstall it rather than install, or uninstall it first. I think the error may be that it thinks it is installed, so it doesn't copy a new version of the file. Then, it tries to access the file, and it's not there as expected.
Marty Fried
  • 18,944
Try reinstalling the python packages via apt-get with the --reinstall option:
$ sudo apt-get install --reinstall python-support python python-minimal python2.7-minimal python2.7 python2.6-minimal python2.6
