I'm currently trying to install an Nvidia gpu driver but receiving the following error:
king@kingss:~$ sudo apt --fix-broken install
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
libamd-comgr2 libhsa-runtime64-1 libibmad5 libucx0 nsight-compute-target
libamdhip64-5 libhsakmt1 libibumad3 linux-image-6.6.9-amd64 nsight-systems-target
Use 'sudo apt autoremove' to remove them.
Installing dependencies:
nvidia-cuda-dev
Summary:
Upgrading: 0, Installing: 1, Removing: 0, Not Upgrading: 282
111 not fully installed or removed.
Download size: 0 B / 705 MB
Space needed: 2410 MB / 0 B available
Warning: More space needed than available: 2410 MB > 0 B, installation may fail
Continue anyway? [y/N]
I have tried to check and understand the filesystem using df which obtained the following:
king@kingss:~$ df
Filesystem 1K-blocks Used Available Use% Mounted on
udev 16279672 0 16279672 0% /dev
tmpfs 3264492 1868 3262624 1% /run
/dev/nvme1n1p2 23854928 23790520 0 100% /
tmpfs 16322448 0 16322448 0% /dev/shm
tmpfs 5120 0 5120 0% /run/lock
efivarfs 248 224 20 93% /sys/firmware/efi/efivars
/dev/nvme1n1p5 1883580 96 1769464 1% /tmp
/dev/nvme1n1p3 9510080 3412800 5592604 38% /var
/dev/nvme1n1p6 454066608 3391032 427536760 1% /home
/dev/nvme1n1p1 500045120 768 500044352 1% /boot/efi
tmpfs 3264488 2552 3261936 1% /run/user/1000
The only partition that appears to be at 100% capacity is /dev/nvme1n1p2.
Would resizing this partition enable the installation?
If yes, how would this be done?
Thankyou
