I use Kubuntu system with several SSD-devices. Most of them use NTFS because I have to use Windows as well.
$ df -h
Filesystem      Size  Used Avail Use% Mounted on
tmpfs           3.2G  3.0M  3.2G   1% /run
/dev/sdc2        55G   45G  7.6G  86% /
tmpfs            16G  235M   16G   2% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
efivarfs        128K   48K   76K  39% /sys/firmware/efi/efivars
/dev/sdc4       164G  105G   51G  68% /home
/dev/sdc3        94M  9.9M   84M  11% /boot/efi
tmpfs           3.2G  7.8M  3.2G   1% /run/user/1000
/dev/sda3       107G   63G   44G  60% /media/username/projects
/dev/sde4       117G  3.9G  114G   4% /media/username/Kubuntu 24.
/dev/sda2       116G   63G   54G  54% /media/username/windows
/dev/sdb2       932G  761G  171G  82% /media/username/games
/dev/nvme0n1p1  1.9T  1.6T  281G  86% /media/username/storage
/dev/sdd1       466G  440G   26G  95% /media/username/hdd
Now one of mounted disk is read only and I don't understand why and how to fix it. I'm talking about /dev/sda3
I checked it on Windows side and it works correctly there. I executed "chkdsk​" in Windows and it returns no errors.
But when I try to update any files and create one more on Kubuntu side I faced with error:
$ touch test
touch: cannot touch 'test': Read-only file system
When I try to use ntfsfix command:
$ sudo ntfsfix /dev/sda3
Mounting volume... OK
Processing of $MFT and $MFTMirr completed successfully.
Checking file system overflow... FAILED
Error: Failed to fix the alternate boot sector
Why? Could someone give some an advice? Rebooting the system doesn't help.
