I have a desktop computer with GL852G USB controller. When I run Windows 7 the USB ports are working OK. When I run Ubuntu none of my USB sticks are detected. Here is the output:
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 22.04.4 LTS
Release:    22.04
Codename:   jammy
$ lsusb Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
$ sudo dmesg | grep -i usb [ 0.464738] ACPI: PM: Power Resource [USBC] [ 0.691678] ACPI: bus type USB registered [ 0.691716] usbcore: registered new interface driver usbfs [ 0.691734] usbcore: registered new interface driver hub [ 0.691749] usbcore: registered new device driver usb [ 0.989472] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.989522] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 0.989560] uhci_hcd: USB Universal Host Controller Interface driver [ 2.883910] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1 [ 2.885491] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2 [ 2.885507] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed [ 2.885605] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15 [ 2.885611] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.885615] usb usb1: Product: xHCI Host Controller [ 2.885618] usb usb1: Manufacturer: Linux 5.15.0-112-generic xhci-hcd [ 2.885621] usb usb1: SerialNumber: 0000:00:14.0 [ 2.885854] hub 1-0:1.0: USB hub found [ 2.887924] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15 [ 2.887934] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.887938] usb usb2: Product: xHCI Host Controller [ 2.887941] usb usb2: Manufacturer: Linux 5.15.0-112-generic xhci-hcd [ 2.887944] usb usb2: SerialNumber: 0000:00:14.0 [ 2.899190] hub 2-0:1.0: USB hub found [ 35.587675] audit: type=1400 audit(1718291948.091:43): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ippusbxd" pid=808 comm="apparmor_parser"
The output of 'dmesg' and 'lsusb' commands doesn't change if I connect or disconnect my USB sticks. They are completely ignored. I have found some discussion of the USB hub. But I don't know how to solve the problem. Same thing happens when I run linux kernel 6.9.3 (installed with 'mainline' command).
