After swapping a faulty router, trying to ssh from PC "A" (Ubuntu 20.04.6) to PC "A", produces the error message: ssh: Could not resolve hostname pca.local: Name or service not known. ping and other such commands can't find the host either.
However, hostname connections from other devices like "pcb" to pca.local, "pca" to pcb.local, "pcb" to pcb.local work. Same with "pca" to "pca" via IP address. Interestingly, connections from "pca" to pca, without the .local, actually work!
But that is useless to me because it is already known in scripts and whatnot as pca.local. All devices in the LAN preserved their IP addresses across router changes.
What I have tried:
cat /etc/hostnameshows its own name as expected.systemctl restart systemd-resolved./etc/init.d/networking restart.dhclient -r eth0.- Can't reboot that machine for a few days.
The output of service avahi-daemon status
● avahi-daemon.service - Avahi mDNS/DNS-SD Stack
Loaded: loaded (/lib/systemd/system/avahi-daemon.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2024-06-12 12:44:47 CST; 1h 49min ago
TriggeredBy: ● avahi-daemon.socket
Main PID: 163913 (avahi-daemon)
Status: "avahi-daemon 0.7 starting up."
Tasks: 2 (limit: 4383)
Memory: 1.3M
CGroup: /system.slice/avahi-daemon.service
├─163913 avahi-daemon: registering [pca.local]
└─163914 avahi-daemon: chroot helper
jun 12 12:44:47 pca avahi-daemon[163913]: Server startup complete. Host name is pca.local. Local service cookie is 2927830272.
jun 12 12:44:47 pca avahi-daemon[163913]: Failed to parse address 'fe80::1%eth0', ignoring.
jun 12 13:08:25 pca avahi-daemon[163913]: Withdrawing address record for fe80::342a:68ff:fec8:fa4e on veth2964dfb.
jun 12 13:08:28 pca avahi-daemon[163913]: Registering new address record for fe80::a881:e7ff:fec7:ead3 on veth6ddcaf7..
jun 12 13:34:33 pca avahi-daemon[163913]: Withdrawing address record for fe80::a881:e7ff:fec7:ead3 on veth6ddcaf7.
jun 12 13:34:35 pca avahi-daemon[163913]: Registering new address record for fe80::5c62:9eff:fe29:543e on veth31f1578..
jun 12 13:53:37 pca avahi-daemon[163913]: Withdrawing address record for fe80::5c62:9eff:fe29:543e on veth31f1578.
jun 12 13:53:40 pca avahi-daemon[163913]: Registering new address record for fe80::c0eb:52ff:fe22:656d on veth6d79f34..
jun 12 14:26:11 pca avahi-daemon[163913]: Withdrawing address record for fe80::c0eb:52ff:fe22:656d on veth6d79f34.
jun 12 14:26:13 pca avahi-daemon[163913]: Registering new address record for fe80::2ce3:93ff:fe4e:8b6f on vethd1fb373..
The output of ip addr show dev eth0
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 6a:55:c4:0f:59:ba brd ff:ff:ff:ff:ff:ff
inet 192.168.1.94/24 brd 192.168.1.255 scope global noprefixroute eth0
valid_lft forever preferred_lft forever
inet6 2806:107e:15:413d:bdc8:3b3e:88ec:370e/64 scope global temporary dynamic
valid_lft 540279sec preferred_lft 21774sec
inet6 2806:107e:15:413d:c92f:8f13:fca8:2576/64 scope global temporary deprecated dynamic
valid_lft 453986sec preferred_lft 0sec
inet6 2806:107e:15:413d:7893:65ce:cb5a:a28c/64 scope global dynamic mngtmpaddr noprefixroute
valid_lft 2441181sec preferred_lft 2441181sec
inet6 fe80::4455:f83b:22ee:5769/64 scope link noprefixroute
Output of avahi-resolve-host-name pca.local
pca.local 192.168.1.94
Output of cat /etc/avahi/avahi-daemon.conf | grep -v "#"
[server]
use-ipv4=yes
use-ipv6=no
ratelimit-interval-usec=1000000
ratelimit-burst=1000
[wide-area]
enable-wide-area=yes
[publish]
publish-hinfo=no
publish-workstation=no
[reflector]
[rlimits]
The output of cat /etc/nsswitch.conf
# /etc/nsswitch.conf
# Example configuration of GNU Name Service Switch functionality.
# If you have the `glibc-doc-reference' and `info' packages installed, try:
# `info libc "Name Service Switch"' for information about this file.
passwd: files
group: files
shadow: files
gshadow: files
hosts: files mymachines dns myhostname
networks: files
protocols: db files
services: db files
ethers: db files
rpc: db files
netgroup: nis
