Ubuntu noob here,
Was messing around with permissions and external disk mounting options and I think I made a mistake with the permissions. Now I can't install updates and the gnome-desktop won't start. I've tried rebooting to no avail.
I couldn't figure out how to make this display properly here so apologies, let me know if there's a better way.
jellyadmin@jellyfin-drake:~$ systemctl start gdm.service
==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
Authentication is required to start 'gdm.service'.
Authenticating as: jellyadmin
Password:
==== AUTHENTICATION COMPLETE ===
Job for gdm.service failed because the control process exited with error code.
See "systemctl status gdm.service" and "journalctl -xeu gdm.service" for details.
jellyadmin@jellyfin-drake:~$ systemctl status gdm.service
× gdm.service - GNOME Display Manager
     Loaded: loaded (/lib/systemd/system/gdm.service; static)
     Active: failed (Result: exit-code) since Tue 2024-06-11 14:32:31 EDT; 18s ago
    Process: 4615 ExecStartPre=/usr/share/gdm/generate-config (code=exited, status=1/FAILURE)
        CPU: 7ms
Jun 11 14:32:31 jellyfin-drake systemd[1]: gdm.service: Scheduled restart job, restart counter is at 5. Jun 11 14:32:31 jellyfin-drake systemd[1]: Stopped GNOME Display Manager. Jun 11 14:32:31 jellyfin-drake systemd[1]: gdm.service: Start request repeated too quickly. Jun 11 14:32:31 jellyfin-drake systemd[1]: gdm.service: Failed with result 'exit-code'. Jun 11 14:32:31 jellyfin-drake systemd[1]: Failed to start GNOME Display Manager. Jun 11 14:32:31 jellyfin-drake systemd[1]: gdm.service: Triggering OnFailure= dependencies. jellyadmin@jellyfin-drake:~$ jellyadmin@jellyfin-drake:~$ jellyadmin@jellyfin-drake:~$ systemctl start displaymanager.target ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units === Authentication is required to start 'displaymanager.target'. Authenticating as: jellyadmin Password: ==== AUTHENTICATION COMPLETE === Failed to start displaymanager.target: Unit displaymanager.target not found. jellyadmin@jellyfin-drake:~$ jellyadmin@jellyfin-drake:~$ jellyadmin@jellyfin-drake:~$ sudo dpkg-reconfigure gdm3 debconf: DbDriver "templatedb": could not write /var/cache/debconf/templates.dat-new: Read-only file system jellyadmin@jellyfin-drake:~$ jellyadmin@jellyfin-drake:~$ jellyadmin@jellyfin-drake:~$ cd / jellyadmin@jellyfin-drake:/$ ls bin boot cdrom dev etc home lib lib32 lib64 libx32 lost+found media mnt opt proc root run sbin snap srv swap.img sys tmp usr var jellyadmin@jellyfin-drake:/$ ls -l total 4194384 lrwxrwxrwx 1 root root 7 Aug 9 2023 bin -> usr/bin drwxr-xr-x 4 root root 4096 Jun 7 06:51 boot dr-xr-xr-x 2 root root 4096 Aug 10 2023 cdrom drwxr-xr-x 20 root root 4700 Jun 11 14:00 dev drwxr-xr-x 156 root root 12288 Jun 11 06:33 etc drwxr-xr-x 3 root root 4096 Feb 4 20:28 home lrwxrwxrwx 1 root root 7 Aug 9 2023 lib -> usr/lib lrwxrwxrwx 1 root root 9 Aug 9 2023 lib32 -> usr/lib32 lrwxrwxrwx 1 root root 9 Aug 9 2023 lib64 -> usr/lib64 lrwxrwxrwx 1 root root 10 Aug 9 2023 libx32 -> usr/libx32 drwx------ 2 root root 16384 Feb 4 20:24 lost+found drwxrwxr-x 5 jellyadmin jellyadmin 4096 Feb 20 09:50 media drwxr-xr-x 11 jellyadmin root 4096 Jun 10 13:47 mnt drwxr-xr-x 4 root root 4096 Feb 10 15:12 opt dr-xr-xr-x 210 root root 0 Jun 11 14:00 proc drwx------ 8 root root 4096 Feb 10 15:08 root drwxr-xr-x 42 root root 1200 Jun 11 14:23 run lrwxrwxrwx 1 root root 8 Aug 9 2023 sbin -> usr/sbin drwxr-xr-x 17 root root 4096 Feb 5 19:05 snap drwxr-xr-x 2 root root 4096 Aug 9 2023 srv -rw------- 1 root root 4294967296 Feb 4 20:25 swap.img dr-xr-xr-x 13 root root 0 Jun 11 14:00 sys drwxrwxrwt 8 root root 4096 Jun 11 12:12 tmp drwxr-xr-x 14 root root 4096 May 30 10:48 usr drwxr-xr-x 14 root root 4096 Feb 4 20:46 var jellyadmin@jellyfin-drake:/$
As suggested:
 Active: failed (Result: exit-code) since Tue 2024-06-11 14:32:31 EDT; 2h 36min ago
    CPU: 7ms
And:
jellyadmin@jellyfin-drake:~$ journalctl -xeu gdm.service
░░ The job identifier is 6945.
Jun 11 14:32:30 jellyfin-drake generate-config[4618]: error: Failed to create file “/var/lib/gdm3/greeter-dconf-defaults.013GP2”: Read-only file system
Jun 11 14:32:30 jellyfin-drake systemd[1]: gdm.service: Control process exited, code=exited, status=1/FAILURE
░░ Subject: Unit process exited
░░ Defined-By: systemd
░░ Support: http://www.ubuntu.com/support
░░ An ExecStartPre= process belonging to unit gdm.service has exited.
░░ The process' exit code is 'exited' and its exit status is 1.
Jun 11 14:32:30 jellyfin-drake systemd[1]: gdm.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ The unit gdm.service has entered the 'failed' state with result 'exit-code'.
Jun 11 14:32:30 jellyfin-drake systemd[1]: Failed to start GNOME Display Manager.
░░ Subject: A start job for unit gdm.service has failed
░░ A start job for unit gdm.service has finished with a failure.
░░ The job identifier is 6945 and the job result is failed.
░░ Subject: Automatic restarting of a unit has been scheduled
░░ Automatic restarting of the unit gdm.service has been scheduled, as the result for
░░ the configured Restart= setting for the unit.
░░ Subject: A stop job for unit gdm.service has finished
░░ A stop job for unit gdm.service has finished.
░░ The job identifier is 7077 and the job result is done.
░░ The job identifier is 7077 and the job result is failed.
lines 1286-1340/1340 (END)
Then:
jellyadmin@jellyfin-drake:~$ findmnt -T /var/lib/gdm3
TARGET SOURCE    FSTYPE OPTIONS
/      /dev/sda2 ext4   ro,relatime
Here's my fstab file:
jellyadmin@jellyfin-drake:/etc$ cat fstab
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/sda2 during curtin installation
# /boot/efi was on /dev/sda1 during curtin installation
/swap.img   none    swap    sw  0   0
/dev/disk/by-uuid/8CD8-C307 /mnt/8CD8-C307 auto nosuid,nodev,nofail,x-gvfs-show 0 0
/dev/disk/by-label/WD_BLACK     /media/jellyadmin/WD_BLACK auto nosuid,nodev,nofail,x-gvfs-show 0 0
/dev/disk/by-label/SG_GREEN     /media/jellyadmin/SG_GREEN auto nosuid,nodev,nofail,x-gvfs-show 0 0
/dev/disk/by-label/EFI /mnt/EFI auto nosuid,nodev,nofail,x-gvfs-show 0 0
/dev/disk/by-label/SG_Green_2     /media//jellyadmin/SG_Green_2 auto nosuid,nodev,nofail,x-gvfs-show 0 0
check current mounted drives:
jellyadmin@jellyfin-drake:/var/snap/firefox/common/host-hunspell$ df -h
Filesystem      Size  Used Avail Use% Mounted on
tmpfs           1.6G  9.5M  1.6G   1% /run
/dev/sda2       915G   44G  826G   5% /
tmpfs           7.8G     0  7.8G   0% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
/dev/sda1       1.1G  6.1M  1.1G   1% /mnt/8CD8-C307
tmpfs           1.6G   64K  1.6G   1% /run/user/1000
And here is what I get when trying to remount the internal drive:
jellyadmin@jellyfin-drake:/dev$ sudo mount -o remount,uid=1000,gid=1000,rw /dev/sda2
mount: /var/snap/firefox/common/host-hunspell: mount point not mounted or bad option.
So I try unmounting and remounting to no avail:
jellyadmin@jellyfin-drake:/$ umount /dev/sda2
umount: /var/snap/firefox/common/host-hunspell: must be superuser to unmount.
jellyadmin@jellyfin-drake:/$ sudo umount /dev/sda2
jellyadmin@jellyfin-drake:/$ df -h
jellyadmin@jellyfin-drake:/$ sudo mount -o remount,uid=1000,gid=1000,rw /dev/sda2 mount: /: mount point not mounted or bad option.
After a fresh install of Ubuntu Server 24.04 LTS, and using the "Disks" app to set only my 3 external drives to auto mount:
jellyadmin@jellyfin-drake:/etc$ df -h
tmpfs                              1.6G  2.0M  1.6G   1% /run
/dev/mapper/ubuntu--vg-ubuntu--lv   98G   14G   80G  15% /
tmpfs                              7.8G  4.0K  7.8G   1%     /dev/shm
tmpfs                              5.0M   12K  5.0M   1%     /run/lock
/dev/sda2                          2.0G  103M  1.7G   6% /boot
/dev/sda1                          1.1G  6.2M  1.1G   1%     /boot/efi
tmpfs                              1.6G  100K  1.6G   1%     /run/user/124
tmpfs                              1.6G  136K  1.6G   1%     /run/user/1000
/dev/sdb1                          1.9T  1.8T   64G  97%     /media/jellyadmin/WD_BLACK
/dev/sdc2                          3.7T  3.5T  185G  96%     /media/jellyadmin/SG_GREEN
/dev/sdd2                          3.7T  812G  2.9T  22%     /media/jellyadmin/SG_Green_2
And:
# / was on /dev/ubuntu-vg/ubuntu-lv during curtin installation
/dev/disk/by-id/dm-uuid-LVM-oOin7c1pI9TWy5aSmyLAJJrNcbiq5Oc1yziartSobMNQQW253V5MUwFaP0zIuXu7 / ext4 defaults 0 1
# /boot was on /dev/sda2 during curtin installation
/dev/disk/by-uuid/2685d670-4f44-4739-84f8-6550f0a08e7b /boot ext4 defaults 0 1
/dev/disk/by-uuid/872E-23CE /boot/efi vfat defaults 0 1
LABEL=SG_GREEN /media/jellyadmin/SG_GREEN auto     nosuid,nodev,nofail,x-gvfs-show 0 0
LABEL=SG_Green_2 /media/jellyadmin/SG_Green_2 auto     nosuid,nodev,nofail,x-gvfs-show 0 0
LABEL=WD_BLACK /media/jellyadmin/WD_BLACK auto     nosuid,nodev,nofail,x-gvfs-show 0 0
My User folder in /media
jellyadmin@jellyfin-drake:/media$ ls -l
total 8
drwxr-x---+ 5 root jellyfinmedia 4096 Jun 19 00:52 jellyadmin
drwxr-x---+ 2 root root          4096 Jun 19 00:43 root
And the containing folders that I can't chown:
jellyadmin@jellyfin-drake:/media/jellyadmin$ ls -l
total 1536
drwxr-xr-x 7 root root  262144 Jun 20 22:25 SG_GREEN
drwxr-xr-x 5 root root  262144 Jun 20 22:25 SG_Green_2
drwxr-xr-x 7 root root 1048576 Jun 20 22:17 WD_BLACK
Check if you have disk space enough. I had a similar issue on a virtual machine until I realized that the root partition was with no disk space, causing that in the boot process appear this error. Remove via terminal some files and reboot the machine work for me. Or try to resize the fully partition. If not is disk space issue this is not are going to work for you. Hope it helps.
