I have the code below to install R 4.3.3 in Ubuntu 20.04. It was working fine until last week. Today, I tried to run it; however, it results in a error.
  export R_VERSION=4.3.3
apt-get update apt-get install -y --no-install-recommends
software-properties-common
dirmngr
wget wget -qO- https://cloud.r-project.org/bin/linux/ubuntu/marutter_pubkey.asc |
tee -a /etc/apt/trusted.gpg.d/cran_ubuntu_key.asc add-apt-repository
"deb https://cloud.r-project.org/bin/linux/ubuntu $(lsb_release -cs)-cran40/" apt-get update apt-get install -y --no-install-recommends
r-base=${R_VERSION}*
r-base-core=${R_VERSION}*
r-base-dev=${R_VERSION}*
r-recommended=${R_VERSION}*
r-base-html=${R_VERSION}*
r-doc-html=${R_VERSION}*
libcurl4-openssl-dev
libssl-dev
libxml2-dev
libcairo2-dev
libxt-dev
libopenblas-dev
libharfbuzz-dev
libfribidi-dev
I have tried multiple suggestions from the solutions on here (i.e. ask ubuntu) without success.Like installing the version directly: apt-get install -y --no-install-recommends r-base-core=4.3.3-1.2004.0. The error:
Reading package lists... Done
Building dependency tree
Selected version '4.3.3-1.2004.0' (CRAN:20.04/focal-cran40 [all]) for 'r-base'
Selected version '4.3.3-1.2004.0' (CRAN:20.04/focal-cran40 [amd64]) for 'r-base-core'
Selected version '4.3.3-1.2004.0' (CRAN:20.04/focal-cran40 [all]) for 'r-base-dev'
The following packages have unmet dependencies: r-base : Depends: r-recommended (= 4.3.3-1.2004.0) but it is not going to be installed E: Unable to correct problems, you have held broken packages. FATAL: While performing build: while running engine: exit status 100
For me this works when installing on ubuntu 22:04:
apt -y install r-base=4.3.3* r-recommended=4.3.3*
Alas furtheron in the R install/compile process 4.4.1 is still being used
