Processor: Intel® Core™ i5-10300H CPU @ 2.50GHz × 8 Graphics Card Nvidia TU106 GeForce RTX 2060 (rev a1)
I broke the screen on my Medion Deputy P10 laptop and replaced it with an LCD from them. During the replacement I switched the laptop on to check it was working but the connector for the LCD was not seated correctly so the screen did not work but the external monitor did. Now the built in display does not work using Ubuntu 20.04 but it does if I boot windows. I also fitted a different SSD and installed ubuntu 24.04 and the built in display still does not work. The display does show the medion splash screen on boot and if I go into recovery shell the built in display is working. After some more time looking at it I can see the the display is actually on, just extremely dim so I wonder if it just the backlight not working.
xrandr:
Screen 0: minimum 8 x 8, current 3840 x 1080, maximum 32767 x 32767
HDMI-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 527mm x 296mm
1920x1080 60.00*+ 59.94 50.00
1600x900 60.00
1280x1024 75.02 60.02
1280x720 60.00 59.94 50.00
1152x864 75.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
DP-0 connected 1920x1080+1920+0 (normal left inverted right x axis y axis) 344mm x 194mm
1920x1080 144.00*+
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
lspci | grep VGA:
01:00.0 VGA compatible controller: NVIDIA Corporation TU106 [GeForce RTX 2060] (rev a1)
lshw -c video:
*-display
description: VGA compatible controller
product: TU106 [GeForce RTX 2060]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:148 memory:b3000000-b3ffffff memory:a0000000-afffffff memory:b0000000-b1ffffff ioport:4000(size=128) memory:b4000000-b407ffff
I think the problem is that the intel integrated graphics are no longer detected, this is the same on ubuntu as well as windows. Windows seems to be able to use the Nvidia card to run the laptop display but I can't see a way to do this on ubuntu. In nvidia-settings I can see the display but I have no 'prime profiles' tab to make the Nvidia card run the built in display as suggested in the answers to similar questions. I have also tried updating the linux kernal to 5.15.0-107-generic x86_64 and the nvidia driver to 550.54.14. I also tried using the nouveaux driver and that got a bit further and displayed the ubuntu splash screen but then just goes to a cursor in the top left of the screen.
Would really appreciate if someone can help me either find the intel integrated hardware or get the Nvidia hardware to run the built in display.
Thanks in advance.
edit:
lshw | grep product
product: Deputy P10 (ML-210008 30029468) product: K15C product: M471A1K43CB1-CTD product: M471A1K43CB1-CTD product: Intel(R) Core(TM) i5-10300H CPU @ 2.50GHz product: 10th Gen Core Processor Host Bridge/DRAM Registers product: Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) product: TU106 [GeForce RTX 2060] product: TU106 High Definition Audio Controller product: TU106 USB 3.1 Host Controller product: xHCI Host Controller product: xHCI Host Controller product: TU106 USB Type-C UCSI Controller product: Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model product: Comet Lake PCH Thermal Controller product: Comet Lake USB 3.1 xHCI Host Controller product: xHCI Host Controller product: HighSpeed Hub product: HHKB Professional product: 2.4G Wireless Mouse product: USB2.0-CRW product: USB2.0 HD UVC WebCam product: xHCI Host Controller product: Comet Lake PCH Shared SRAM product: Wi-Fi 6 AX201 product: Comet Lake PCH Serial IO I2C Controller #0 product: Comet Lake PCH Serial IO I2C Controller #1 product: Comet Lake HECI Controller product: Intel Corporation product: Comet Lake PCI Express Root Port #9 product: E12 NVMe Controller product: E12S-512G-PHISON-SSD-B27B product: Intel Corporation product: QCA8171 Gigabit Ethernet product: Comet Lake LPC Controller product: Comet Lake PCH cAVS product: Comet Lake PCH SMBus Controller product: Comet Lake PCH SPI Controller product: PnP device PNP0c02 product: PnP device PNP0c02 product: PnP device INT3f0d product: PnP device PNP0303 product: PnP device PNP0c02 product: PnP device PNP0c02 product: PnP device PNP0c02 product: PnP device PNP0c02 product: To Be Filled By O.E.M.
edit 2:
I have just noticed that the display is actually on, it is just extremely dim, if I put a window with a white background on it then I can tell there is something there but it is too dim to see.
