31
Hope you are doing well. The problem started to show up after I upgraded Ubuntu 23.10 ---> Ubuntu 24.04 LTS (through the Gnome Software Updater).
Here is the output of the sudo apt update -y command:
$ sudo apt update -y
Hit:1 https://archive.ubuntu.petiak.ir/ubuntu noble InRelease
Hit:2 https://archive.ubuntu.petiak.ir/ubuntu noble-updates InRelease
Hit:3 https://archive.ubuntu.petiak.ir/ubuntu noble-backports InRelease
Hit:4 https://dl.google.com/linux/chrome/deb stable InRelease
Reading package lists... Done
Building dependency tree... Done
19 packages can be upgraded. Run 'apt list --upgradable' to see them.
N: Skipping acquire of configured file 'main/binary-i386/Packages' as repository 'https://dl.google.com/linux/chrome/deb stable InRelease' doesn't support architecture 'i386'
N: Missing Signed-By in the sources.list(5) entry for 'https://archive.ubuntu.petiak.ir/ubuntu'
Disorder parts:
Toghrol
  • 433
9 Answers9
16
Taking the hint from https://www.digitalocean.com/community/questions/n-missing-signed-by-in-the-sources-list-5-entry-for-http-mirrors-digitalocean-com-ubuntu I added:
Signed-By: /usr/share/keyrings/ubuntu-archive-keyring.gpg
To each entry in my /etc/apt/sources.list.d/ file, that being for gb.archive.ubuntu.com and security.ubuntu.com in my case. That's fixed the error and all sources are now downloaded and verified.
I assume I ran into this due to it being an old, upgraded multiple times, install, including that I probably hand-adjusted the sources file at some point. It was still the old "just a single line per source" style before this upgrade from LTS 22, through 23, to LTS 24.
10
In my case what helped is removing the country prefix from /etc/apt/sources.list.d/ubuntu.sources.
So it was before
URIs: http://ru.archive.ubuntu.com/ubuntu/
and then it became:
URIs: http://archive.ubuntu.com/ubuntu/
I am not exactly sure what's causing it (perhaps some missing key?), but it's clearly some misconfiguration on the Ubuntu 24.04 installer side.
Hi-Angel
  • 4,810
Ran into this myself yesterday. I solved the issue as follows:
  • I'm in New Zealand, so I use http://nz.archive.ubuntu.com/ubuntu, not the more generic http://archive.ubuntu.com/ubuntu. For some reason, the update to 24.04 re-set the URLs to the generic, non-regional URL. Prefixing nz. to all URLs in all files named archive_uri-http_archive_ubuntu_com_ubuntu-* in /etc/apt/sourced.d.list/ got me a step further.
  • I copied the Signed-By: line mentioned in /etc/apt/sources.list.d/ubuntu.sources to all archive_uri-http_archive_ubuntu_com_ubuntu-* files in the same directory. This works, because the URL in ubuntu.sources is the regional nz.archive.ubuntu.com I now copy-pasted to all the archive_* files in the previous steps.
  • Running sudo apt update then gave me a bunch of warnings, similar to
W: Target CNF (universe/cnf/Commands-all) is configured multiple times in /etc/apt/sources.list.d/archive_uri-http_archive_ubuntu_com_ubuntu-impish.sources:1 and /etc/apt/sources.list.d/ubuntu.sources:1
  • Checking the offending file archive_uri-http_archive_ubuntu_com_ubuntu-impish.sources showed that it was indeed basically a duplicate of the contents of ubuntu.sources, so I moved it out of the way (sudo mv archive_uri-http_archive_ubuntu_com_ubuntu-impish.sources ~/)
After all this, I could run sudo apt update without errors/warnings.
I'm not 100% sure what the URL should be in your case. Have a look what's there in ubuntu.sources. It could be worth looking for a faster one on the mirror list. Looking under Iran I'd think that Saba Abr Mizban or Tegra host should be much faster than the one you're currently using.
  1. Find sources that contain us.archive.ubuntu.com
    grep -r "us.archive.ubuntu.com" /etc/apt/
    /etc/apt/sources.list.d/us_archive_ubuntu_com_ubuntu.sources:URIs: http://us.archive.ubuntu.com/ubuntu
    /etc/apt/sources.list.d/us_archive_ubuntu_com_ubuntu.list.save:deb http://us.archive.ubuntu.com/ubuntu focal multiverse
    /etc/apt/sources.list.d/us_archive_ubuntu_com_ubuntu.list.distUpgrade:deb http://us.archive.ubuntu.com/ubuntu noble multiverse
  2. Edit us_archive_ubuntu_com_ubuntu.sources file by adding Signed-By: /usr/share/keyrings/ubuntu-archive-keyring.gpg to the end of the file.
    sudo vim /etc/apt/sources.list.d/us_archive_ubuntu_com_ubuntu.sources
NOTE: I edited only one file, not all!
For serverloft.eu urls, my /etc/apt/sources.list.d/third-party.sources file now looks like this, after simply adding the last line, and now the warnings are gone:
Types: deb deb-src
URIs: http://ubuntu.mirror.serverloft.eu/ubuntu
Suites: noble noble-updates noble-security
Components: main restricted universe multiverse
For aliyun mirror, I add the following line to the end of third-party.sources to fix this problem. But I wonder if I should ask for the GPG from Aliyun mirror site?
cat third-party.sources
Types: deb deb-src
URIs: http://mirrors.aliyuncs.com/ubuntu/
Suites: noble noble-updates noble-security noble-backports noble-proposed
Signed-by: /usr/share/keyrings/ubuntu-archive-keyring.gpg
UBUNTU 24.04.1 After Install (UEFI) =
sudo nano /etc/apt/sources.list
copy paste this =
deb http://archive.ubuntu.com/ubuntu/ noble main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu/ noble-updates main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu/ noble-security main restricted universe multiverse
Control X for exit, Y for Yes to save, enter, now =
sudo apt update
ISRAEL
  • 89
You can switch from local to US, run command as usual sudo apt update -y from terminal and that will fix this error. No hand made modifications are required.
Software & Updates
Before:
After:
in my case this happened as i used a cloud image, for some reason they have "cloud.archive" in from of the URI, i removed that and WOILA. That archive image is where the config bug is.
