Today (04.06.2024) I used my lenovo yoga slim 7 pro running ubuntu 22.04.4 LTS for the first time since 02.06.2024. Everything worked as it was supposed to the last time, but now there is a issue with the network controller: "No WiFi adapter is found" in settings. So it would seem that a automatic update has broken the network drivers.
Here is some info about the network controller:
Running sudo lshw -C network gives:
Network controller
product: Alder Lake-P PCH CNVi WiFi
vendor: Intel Corporation
physical id: 14.3
bus info: pci@0000:00:14.3
version: 01
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list
configuration: driver=iwlwifi latency=0
resources: iomemory:600-5ff irq:16 memory:601d1cc000-601d1cffff
and running lspci -knn | grep Net -A3 gives:
00:14.3 Network controller [0280]: Intel Corporation Alder Lake-P PCH CNVi WiFi [8086:51f0] (rev 01)
Subsystem: Intel Corporation Device [8086:0094]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
What I have tried:
- Updated the network driver to its latest version both through snap store and using
sudo apt install backport-iwlwifi-dkmsfrom this post - Added the line:
options iwlwifi 11n_disable=1 swcrypto=1to/etc/modprobe.d/iwlwifi.conffrom this post
None of the above worked.
