I am new to Ubuntu and I installed Ubuntu as standalone OS on my brand-new Lenovo laptop and using it for past 3 months. To check if my adapter has problem, I plugged in another adapter, but same problem persist. This issue has started today, before this it was charging normal even at 100% charge the bolt/flash icon always showed up.
If I plugged in an adapter, then % of battery remains stationary. It is showing 95% from last 1 hr, but if I remove the adapter it discharges and % decreases. But again, on plugging in adapter the % of battery won't increase.
Is there any solution to this issue?
Used following command: upower -i /org/freedesktop/UPower/devices/battery_BAT0
and this is the what I got:
native-path: BAT0
vendor: SMP
model: L20M2PF0
serial: 1815
power supply: yes
updated: Monday 03 June 2024 03:40:49 PM (10 seconds ago)
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: pending-charge
warning-level: none
energy: 35.73 Wh
energy-empty: 0 Wh
energy-full: 37.31 Wh
energy-full-design: 38 Wh
energy-rate: 0.773 W
voltage: 8.681 V
charge-cycles: 74
percentage: 95%
capacity: 98.1842%
technology: lithium-polymer
icon-name: 'battery-full-charging-symbolic'
Ubi.B
  • 111
