I am trying to install Flutter on my Ubuntu 22 and the dependencies installed, system upto date. No issues. System info:
64 bit system. Ubuntu 22.04 installed. For some reason Flutter doc suggest installing these 32 bit packages.
But when I try this step-
sudo apt-get install \
libc6:i386 libncurses5:i386 \
libstdc++6:i386 lib32z1 \
libbz2-1.0:i386
It fails with the output-
apt : Depends: adduser but it is not going to be installed
Depends: gpgv or
gpgv2 but it is not going to be installed or
gpgv1 but it is not going to be installed
Depends: libapt-pkg6.0 (>= 2.4.11) but it is not going to be installed
Depends: libc6 (>= 2.34) but it is not installable
Depends: libgcc-s1 (>= 3.3.1) but it is not going to be installed
Depends: libgnutls30 (>= 3.7.0) but it is not going to be installed
Depends: libseccomp2 (>= 2.4.2) but it is not going to be installed
Depends: libstdc++6 (>= 11) but it is not going to be installed
Depends: libsystemd0 but it is not going to be installed
Recommends: ca-certificates but it is not going to be installed
base-files : PreDepends: awk
base-passwd : Depends: libc6 (>= 2.34) but it is not installable
Depends: libdebconfclient0 (>= 0.145) but it is not going to be installed
bash : PreDepends: libc6 (>= 2.34) but it is not installable
PreDepends: libtinfo6 (>= 6) but it is not going to be installed
bsdutils : PreDepends: libc6 (>= 2.34) but it is not installable
PreDepends: libsystemd0 but it is not going to be installed
Recommends: bsdextrautils
coreutils : PreDepends: libacl1 (>= 2.2.23) but it is not going to be installed
PreDepends: libattr1 (>= 1:2.4.44) but it is not going to be installed
PreDepends: libgmp10 (>= 2:6.2.1+dfsg) but it is not going to be installed
PreDepends: libselinux1 (>= 3.1~) but it is not going to be installed
dash : PreDepends: libc6 (>= 2.34) but it is not installable
debianutils : PreDepends: libc6 (>= 2.34) but it is not installable
diffutils : PreDepends: libc6 (>= 2.34) but it is not installable
dpkg : PreDepends: libbz2-1.0 but it is not going to be installed
PreDepends: liblzma5 (>= 5.2.2) but it is not going to be installed
PreDepends: libzstd1 (>= 1.4.0) but it is not going to be installed
PreDepends: zlib1g (>= 1:1.1.4) but it is not going to be installed
e2fsprogs : PreDepends: libblkid1 (>= 2.36) but it is not going to be installed
PreDepends: libcom-err2 (>= 1.43.9) but it is not going to be installed
PreDepends: libext2fs2 (= 1.46.5-2ubuntu1.1) but it is not going to be installed
PreDepends: libss2 (>= 1.38) but it is not going to be installed
PreDepends: libuuid1 (>= 2.16) but it is not going to be installed
Depends: logsave
Recommends: e2fsprogs-l10n but it is not going to be installed
findutils : PreDepends: libc6 (>= 2.34) but it is not installable
grep : PreDepends: libc6 (>= 2.34) but it is not installable
PreDepends: libpcre3 but it is not going to be installed
gzip : PreDepends: libc6 (>= 2.34) but it is not installable
hostname : PreDepends: libc6 (>= 2.34) but it is not installable
init : PreDepends: systemd-sysv
libc-bin : Depends: libc6 (> 2.35) but it is not installable
Depends: libc6 (< 2.36) but it is not installable
libcrypt1 : Depends: libc6 (>= 2.25) but it is not installable
login : PreDepends: libaudit1 (>= 1:2.2.1) but it is not going to be installed
PreDepends: libpam0g (>= 0.99.7.1) but it is not going to be installed
PreDepends: libpam-runtime but it is not going to be installed
PreDepends: libpam-modules but it is not going to be installed
ncurses-bin : PreDepends: libc6 (>= 2.34) but it is not installable
PreDepends: libtinfo6 (>= 6.3) but it is not going to be installed
perl-base : PreDepends: libc6 (>= 2.35) but it is not installable
sed : PreDepends: libacl1 (>= 2.2.23) but it is not going to be installed
shim-signed : Depends: grub-efi-amd64-signed (>= 1.187.2~) but it is not going to be installed or
grub-efi-arm64-signed (>= 1.187.2~) but it is not installable
Depends: grub2-common (>= 2.04-1ubuntu24)
Depends: mokutil (>= 0.3.0+1538710437.fb6250f-0ubuntu2) but it is not going to be installed
Depends: sbsigntool but it is not going to be installed
Recommends: secureboot-db but it is not going to be installed
sysvinit-utils : Depends: libc6 (>= 2.34) but it is not installable
tar : PreDepends: libacl1 (>= 2.2.23) but it is not going to be installed
util-linux : PreDepends: libaudit1 (>= 1:2.2.1) but it is not going to be installed
PreDepends: libblkid1 (>= 2.37.2) but it is not going to be installed
PreDepends: libcap-ng0 (>= 0.7.9) but it is not going to be installed
PreDepends: libmount1 (>= 2.37.2) but it is not going to be installed
PreDepends: libsmartcols1 (>= 2.34) but it is not going to be installed
PreDepends: libudev1 (>= 183) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Not sure how to deal with the issue. i386 already configured.
