I found the setfacl from this link:
https://stackoverflow.com/questions/39397548/how-to-give-non-root-user-in-docker-container-access-to-a-volume-mounted-on-the
sudo setfacl -m u:$(id -u):rwx -R /some/folder
But it will set all file permissions into rwx which is different from my requirement.
Here is the test folder:
rm -rf /test
mkdir -p /test/hello/world
echo "hello" > /test/hello.txt
echo "hi" > /test/hi.sh chmod 755 /test/hi.sh
echo "foo" > /test/foo.sh chmod 400 /test/foo.sh
echo "bar" > /test/bar.sh chmod 700 /test/bar.sh
Here is the file permissions:
# ls -l /test
-rwx------ 1 root root 4 Jun 1 12:20 bar.sh -r-------- 1 root root 4 Jun 1 12:20 foo.sh drwxr-xr-x 3 root root 4096 Jun 1 12:20 hello -rw-r--r-- 1 root root 6 Jun 1 12:20 hello.txt -rwxr-xr-x 1 root root 3 Jun 1 12:20 hi.sh
I want to grant user 1234 the same permission as root:
sudo setfacl -m u:1234:(???) -R /test
Here is the expected permission for user 1234 (not changing the owner here, just use 1234 in here for explaining the detail permissions as the same as user root):
# ls -l /test
-rwx------ 1 1234 root 4 Jun 1 12:20 bar.sh -r-------- 1 1234 root 4 Jun 1 12:20 foo.sh drwxr-xr-x 3 1234 root 4096 Jun 1 12:20 hello -rw-r--r-- 1 1234 root 6 Jun 1 12:20 hello.txt -rwxr-xr-x 1 1234 root 3 Jun 1 12:20 hi.sh
How to write this sudo setfacl -m u:1234:(???) -R /test?
Raffa
  • 34,963
stackbiz
  • 495
Just a pointer as I consider this a bit clumsy ... But, you'll get the point.
In a shell loop:
for i in /test/*; do
  p="$(getfacl "$i" | awk -F'::' '/user::/{printf $2}')"
  setfacl --test -m u:1234:"$p" "$i"
done
That was a dry-run ... When satisfied with the output, remove --test and re-run it again to actually modify ACLs.
Raffa
  • 34,963
