I'm using a 2TB WD Black SN770 NVMe SSD on an MSI MAG Tomahawk B550 mobo. The system boots, but it takes way too long (approx. 3 minutes) and it will NOT reboot from the $ reboot command nor from the hardware reset button on the computer; no video either way.
When I turn power off and back on, I get the Kubuntu boot screen
*Kubuntu
Kubuntu Advanced Options
Kubuntu safe recovery
remaining lines from the standard menu
I select the 1st or 2nd line (generic kernel) and wait because the next screen looks like this:
[ 0.001259] __common_interrupt: 1.55 No irq handler for vector
[ 0.001259] __common_interrupt: 2.55 No irq handler for vector
[ 0.001259] __common_interrupt: 3.55 No irq handler for vector
[ 0.001259] __common_interrupt: 4.55 No irq handler for vector
[ 0.001259] __common_interrupt: 5.55 No irq handler for vector
[ 0.001259] __common_interrupt: 6.55 No irq handler for vector
[ 0.001259] __common_interrupt: 7.55 No irq handler for vector
[ 0.001259] __common_interrupt: 8.55 No irq handler for vector
[ 0.001259] __common_interrupt: 9.55 No irq handler for vector
[ 0.001259] __common_interrupt: 10.55 No irq handler for vector
That stays on the monitor for about 3 minutes then my system boots up with the following issues:
Default wallpaper; the one I setup is gone. All the other settings are I modified are good.
I was under the impression that NVMe SSDs on the PCI bus allows a system to boot considerably faster so I'm thinking this is something that can be fixed. Please advise.
