I tried to install Rancher Desktop on Ubuntu Server 24.04.
This is the official guide:
https://docs.rancherdesktop.io/getting-started/installation/#linux
I did every setting before installation.
But when I install via sudo apt install rancher-desktop, these dependency errors happened:
$ sudo apt install rancher-desktop
Reading package lists... Done
Building dependency tree... Done
rancher-desktop:amd64 : Depends: pass:amd64 but it is not installable
Depends: libasound2:amd64 but it is not installable
Depends: libatk1.0-0:amd64 but it is not installable
Depends: libatk-bridge2.0-0:amd64 but it is not installable
Depends: libatspi2.0-0:amd64 but it is not installable
Depends: libc6:amd64 but it is not installable
Depends: libcairo2:amd64 but it is not installable
Depends: libcups2:amd64 but it is not installable
Depends: libdbus-1-3:amd64 but it is not installable
Depends: libdrm2:amd64 but it is not installable
Depends: libexpat1:amd64 but it is not installable
Depends: libgbm1:amd64 but it is not installable
Depends: libgcc1:amd64 but it is not installable
Depends: libgdk-pixbuf2.0-0:amd64 but it is not installable
Depends: libglib2.0-0:amd64 but it is not installable
Depends: libglib2.0-dev:amd64 but it is not installable
Depends: libgtk-3-0:amd64 but it is not installable
Depends: libnspr4:amd64 but it is not installable
Depends: libnss3:amd64 but it is not installable
Depends: libpango-1.0-0:amd64 but it is not installable
Depends: libx11-6:amd64 but it is not installable
Depends: libxcb1:amd64 but it is not installable
Depends: libxcomposite1:amd64 but it is not installable
Depends: libxdamage1:amd64 but it is not installable
Depends: libxext6:amd64 but it is not installable
Depends: libxfixes3:amd64 but it is not installable
Depends: libxkbcommon0:amd64 but it is not installable
Depends: libxrandr2:amd64 but it is not installable
I have installed pass. How many necessary dependencies should been installed before this operation?
