I've installed ubuntu 24.04 on my geecom A7. And I wasn't able to figure out why bluetooth is not working. Problem looks same as described here:
https://www.cnx-software.com/2024/02/24/geekom-a7-mini-pc-review-ubuntu-22-04-ubuntu-24-04-linux/
For the record, bluetooth works fine on windows (on same mini PC).
  1. rfkill shows that Bluetooth is not blocked.
rfkill list all
0: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
  1. bluetoothctl reports that there is no default controller.
[bluetooth]# devices
No default controller available
  1. lsmod shows
lsmod | grep bluetooth
bluetooth            1089536  15 btrtl,btmtk,btintel,btbcm,bnep,btusb
ecdh_generic           16384  1 bluetooth
  1. systemcltl shows
systemctl status bluetooth.service
● bluetooth.service - Bluetooth service
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: enabled)
     Active: active (running) since Fri 2024-05-24 11:05:05 CST; 13min ago
       Docs: man:bluetoothd(8)
   Main PID: 1029 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 37566)
     Memory: 2.8M (peak: 3.1M)
        CPU: 32ms
     CGroup: /system.slice/bluetooth.service
             └─1029 /usr/libexec/bluetooth/bluetoothd
May 24 11:05:05 terrasoff-A7 systemd[1]: Started bluetooth.service - Bluetooth service. May 24 11:05:05 terrasoff-A7 bluetoothd[1029]: Starting SDP server May 24 11:05:05 terrasoff-A7 bluetoothd[1029]: src/plugin.c:plugin_init() System does not support csip plugin May 24 11:05:05 terrasoff-A7 bluetoothd[1029]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled May 24 11:05:05 terrasoff-A7 bluetoothd[1029]: src/plugin.c:plugin_init() System does not support micp plugin May 24 11:05:05 terrasoff-A7 bluetoothd[1029]: src/plugin.c:plugin_init() System does not support vcp plugin May 24 11:05:05 terrasoff-A7 bluetoothd[1029]: src/plugin.c:plugin_init() System does not support mcp plugin May 24 11:05:05 terrasoff-A7 bluetoothd[1029]: src/plugin.c:plugin_init() System does not support bass plugin May 24 11:05:05 terrasoff-A7 bluetoothd[1029]: src/plugin.c:plugin_init() System does not support bap plugin May 24 11:05:05 terrasoff-A7 bluetoothd[1029]: Bluetooth management interface 1.22 initialized
  1. dmesg | grep -i bluetooth shows
[    6.914793] Bluetooth: Core ver 2.22
[    6.914815] NET: Registered PF_BLUETOOTH protocol family
[    6.914816] Bluetooth: HCI device and connection manager initialized
[    6.914819] Bluetooth: HCI socket layer initialized
[    6.914821] Bluetooth: L2CAP socket layer initialized
[    6.914825] Bluetooth: SCO socket layer initialized
[    8.512540] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    8.512545] Bluetooth: BNEP filters: protocol multicast
[    8.512549] Bluetooth: BNEP socket layer initialized
[    8.933590] Modules linked in: qrtr bnep binfmt_misc intel_rapl_msr nls_iso8859_1 intel_rapl_common snd_hda_codec_realtek amdgpu(+) edac_mce_amd snd_hda_codec_generic snd_hda_codec_hdmi kvm_amd snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi kvm snd_hda_codec irqbypass snd_hda_core mt7921e crct10dif_pclmul snd_hwdep amdxcp mt7921_common polyval_clmulni btusb snd_pcm drm_exec mt792x_lib polyval_generic btrtl gpu_sched snd_seq_midi mt76_connac_lib ghash_clmulni_intel btintel drm_buddy snd_seq_midi_event mt76 sha256_ssse3 btbcm drm_suballoc_helper drm_ttm_helper snd_rawmidi sha1_ssse3 btmtk ttm snd_seq mac80211 aesni_intel bluetooth drm_display_helper snd_seq_device crypto_simd snd_timer cec ecdh_generic cryptd rc_core cfg80211 snd ecc wmi_bmof rapl i2c_algo_bit input_leds joydev ccp soundcore k10temp libarc4 i2c_piix4 apple_mfi_fastcharge amd_pmc mac_hid msr parport_pc ppdev lp parport efi_pstore nfnetlink dmi_sysfs ip_tables x_tables autofs4 hid_logitech_hidpp hid_logitech_dj hid_apple hid_generic usbhid sdhci_pci
[    9.061366] Bluetooth: hci0: Opcode 0x0c03 failed: -110
  1. lsusb doesn't show my Bluetooth name:
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 13d3:3585 IMC Networks Wireless_Device
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 005 Device 005: ID 046d:c534 Logitech, Inc. Unifying Receiver
Bus 005 Device 006: ID 05ac:024f Apple, Inc. Aluminium Keyboard (ANSI)
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 006 Device 002: ID 05e3:0625 Genesys Logic, Inc. USB3.2 Hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  1. hcitool dev doesn't find any bluetooth device.
  2. /var/lib/bluetooth is empty
  3. lspci shows
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14e8
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Device 14e9
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14ea
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14ea
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14ee
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14ee
00:02.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14ee
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14ee
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14ea
00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 19h USB4/Thunderbolt PCIe tunnel
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14ea
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14ea
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14eb
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14eb
00:08.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 14eb
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 71)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14f0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14f1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14f2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14f3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14f4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14f5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14f6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Device 14f7
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller (rev 05)
02:00.0 Network controller: MEDIATEK Corp. MT7922 802.11ax PCI Express Wireless Network Adapter
03:00.0 SD Host controller: O2 Micro, Inc. SD/MMC Card Reader Controller (rev 01)
04:00.0 Non-Volatile memory controller: Phison Electronics Corporation PS5021-E21 PCIe4 NVMe Controller (DRAM-less)
65:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Phoenix1 (rev c2)
65:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Rembrandt Radeon High Definition Audio Controller
65:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 19h (Model 74h) CCP/PSP 3.0 Device
65:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Device 15b9
65:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Device 15ba
65:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller
65:00.7 Signal processing controller: Advanced Micro Devices, Inc. [AMD] Device 164a
66:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device 14ec
66:00.1 Signal processing controller: Advanced Micro Devices, Inc. [AMD] AMD IPU Device
67:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device 14ec
67:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Device 15c0
67:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Device 15c1
67:00.5 USB controller: Advanced Micro Devices, Inc. [AMD] Pink Sardine USB4/Thunderbolt NHI controller #1
Any ideas how to fix it?
6 Answers6
I just upgraded from 22.04 to 24.04 and ran into the exact same problem. Found a "solution" that had me entering in terminal:
systemctl --user enable pulseaudio
systemctl --user start pulseaudio
This worked for me but it does not persist between sessions. Had to add these two lines to my .xsessionrc file in my home directory to make it persist. That's not a real solution but, until a real fix is released, it has to do.
z-man
  • 121
First remove the config file for PulseAudio with:
rm  -rf ~/.config/pulse/*
Then restart your machine where the PulseAudio will be reconfigured automatically giving you a dependency error. For my case, the desktop environment did not load at first. So I installed GNOME via terminal. Οnce installed, I tried to install a different environment for Ubuntu 24.04 with:
sudo apt install ubuntu-unity-desktop
This gives an error message:
 ubuntu-unity-desktop : Depends: pulseaudio
                        Recommends: pulseaudio-module-bluetooth but it is not going to be installed
So I installed the recommended package, pulseaudio-module-bluetooth, which worked fine. However the Bluetooth couldn't connect and hold, so I inputted the following commands to fix this:
followed by:
Worked perfectly.
I had a similar problem. While searching for a solution, I focused my attention on the
I've checked if Bluetooth firmware is installed by the command:
ls /lib/firmware/brcm
There should be a file BCM43142A0-0a5c-21d7.hcd or similar to that.
I didn't have it. Then that file was downloaded and copied to /lib/firmware/brcm from https://github.com/winterheart/broadcom-bt-firmware
In my case:
sudo cp BCM43142A0-105b-e065.hcd /lib/firmware/brcm/
The next step is restarting the Bluetooth service btusb
sudo modprobe -r btusb
sudo modprobe btusb
sudo systemctl restart bluetooth
That was useful for me. For testing run:
bluetoothctl
[bluetooth]# power on
Hope it will be useful.
Andrew
I have the same issue as the main question, I have tried everything, it seems to be an issue with MT7921e chipset and its firmware, the weired thing is that this chipset controls both wifi and bluetooth, and wifi workd fine, for sure your situation is the same
I had a similar issue (not sure if it's exactly the same): basically the bluetooth connections worked perfectly fine for a few times after installation until it suddenly just... stopped working. It couldn't find any devices at all. I've tried every single suggestion I could find on the internet, from restarting the bluetooth service, the pulseaudio ones, downloading the driver ones, extracting the .zst files in /lib/firmware/brcm, installing blueman, etc. to just rebooting everything. Nothing worked, until I found this little reply on reddit:
https://www.reddit.com/r/Ubuntu/comments/1cf30qo/comment/lo6ks4x/?utm_source=share&utm_medium=web3x&utm_name=web3xcss&utm_term=1&utm_content=share_button
Basically, just let the battery completely drains out, charge it and start the laptop. And voila! It magically works now.
I hope this might work for you and for anyone else coming across this!
I have tried all solutions proposed here at this time and none worked... I just activated the proprietary driver for Nvidia and all worked fine.
In my case I used the recommended one: nvidia-driver-570 on a Latitude-5580
