I have the following issue. I upgraded from 22.04 LTS to 23.04 LTS and finally to 24.04 LTS.
Main monitor (monitor 1) After the upgrades the installation is ok. When I maximize a window the buttons do not work any more (red area), when I press any of the read area clicks. In this case AnyDesk. if I move the maximized window I have the same behavior. Working with minimized window works ok.
Second Monitor (monitor 2) Does not have this issue. The issue is that the second monitor screen blinks all the time.
Regarding the issue tried the following.
I'll try a clean installation this weekend and go back with comments.
David DE
  • 2,316
A new installation was needed. Anydesk generated some issues with the top icon, blocking the options of the top right corner.
More problems with overheat during a normal use of Ubuntu 24.04. This happen with Dell Latitud 5290.
Problem is caused by Anydesk icon on top bar. If you disable anydesk.service, the problem is gone. To do that you can use:
sudo systemctl disable anydesk.service
When you open Anydesk, problem will come back, I hope they will solve this soon.
zx485
  • 2,865
Just simply go to /usr/share/gnome-shell/extensions/ubuntu-appindicators@ubuntu.com
if file is there just simply rename it with appIndicator.bak.
sudo mv appIndicator.js appIndicator.bak
and just restart your system.
