guys im getting this error when trying to install sdl2 or libsdl2-dev on lubuntu 22.04
Reading package lists... Done
Building dependency tree... Done
libsdl2-2.0-0 : Depends: libdecor-0-0 (>= 0.2.2+git2403041401.4f2c03d~j~wayland1) but 0.1.0-3build1 is to be installed
is this a known issue? i tried to install libdecor-0 0.2.2 manually but didnt worked
