My Ubuntu 20.04 suddenly stopped coming up. I enter a password, things crank for a bit, and then I am asked for a password again. This can go on and on.
I am able to bring up 16.04, and using it, I have done a bit of sleuthing, I have determined the following: The attempt to being up 20.04 creates the following files in /var/log
auth.log
boot.log
gpu-manager.log
kern.log
mail.err
mail.lor
syslog
wtmp.log
Xorg.0.log
Using grep I have checked for the word "error" (case-insensitive) and it is found only in kern.log, mail.err, and syslog. Attached are these files:
mail.err
kern.err (error lines from kern.log)
syslog.err (error lines from syslog - entire syslog available if requested)
I would greatly appreciate any enlightenment about what is going on and how to fix it.
Roger House Software Developer
mail.err
May 21 15:43:01 ada sm-mta[1735]: My unqualified host name (ada) unknown; sleeping for retry
May 21 15:43:03 ada sm-msp-queue[1818]: My unqualified host name (ada) unknown; sleeping for retry
May 21 15:44:01 ada sm-mta[1735]: unable to qualify my own domain name (ada) -- using short name
May 21 15:44:03 ada sm-msp-queue[1818]: unable to qualify my own domain name (ada) -- using short name
kern.err
May 21 15:42:56 ada kernel: [ 3.352957] EXT4-fs (sdb6): re-mounted. Opts: errors=remount-ro
May 21 15:42:57 ada NetworkManager[1039]: <warn> [1716331377.0371] failed to enumerate oFono devices: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.ofono was not provided by any .service files
syslog.err
May 21 15:42:56 ada gpu-manager[1040]: Error: can't open /lib/modules/4.4.0-179-generic/updates/dkms
May 21 15:42:56 ada gpu-manager[1040]: update-alternatives: error: no alternatives for x86_64-linux-gnu_gfxcore_conf
May 21 15:42:56 ada unattended-upgrade-shutdown[1216]: ModuleNotFoundError: No module named '_dbus_bindings'
May 21 15:43:02 ada udev-configure-printer[1567]: ModuleNotFoundError: No module named 'cups'
May 21 15:43:02 ada ntpd[1699]: error resolving pool 0.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
May 21 15:43:03 ada ntpd[1699]: error resolving pool 1.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
May 21 15:43:04 ada ntpd[1699]: error resolving pool 2.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
May 21 15:43:05 ada ntpd[1699]: error resolving pool 3.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
May 21 15:43:06 ada ntpd[1699]: error resolving pool ntp.ubuntu.com: Temporary failure in name resolution (-3)
May 21 15:43:08 ada org.a11y.Bus[1978]: ** (process:2065): WARNING **: Failed to register client: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.gnome.SessionManager was not provided by any .service files
May 21 15:43:19 ada snapd[997]: stateengine.go:150: state ensure error: Get https://api.snapcraft.io/api/v1/snaps/sections: dial tcp: lookup api.snapcraft.io on [::1]:53: read udp [::1]:33159->[::1]:53: read: connection refused
May 21 15:43:37 ada pulseaudio[2096]: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
May 21 15:44:06 ada ntpd[1699]: error resolving pool 0.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
May 21 15:44:08 ada ntpd[1699]: error resolving pool 1.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
May 21 15:44:09 ada ntpd[1699]: error resolving pool 3.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
May 21 15:44:10 ada ntpd[1699]: error resolving pool ntp.ubuntu.com: Temporary failure in name resolution (-3)
May 21 15:44:11 ada ntpd[1699]: error resolving pool 2.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
May 21 15:45:12 ada ntpd[1699]: error resolving pool 1.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
May 21 15:45:13 ada ntpd[1699]: error resolving pool 0.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
May 21 15:45:14 ada ntpd[1699]: error resolving pool 3.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
May 21 15:45:15 ada ntpd[1699]: error resolving pool ntp.ubuntu.com: Temporary failure in name resolution (-3)
May 21 15:45:18 ada ntpd[1699]: error resolving pool 2.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
May 21 15:46:17 ada ntpd[1699]: error resolving pool 1.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
May 21 15:46:20 ada ntpd[1699]: error resolving pool 0.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
May 21 15:46:21 ada ntpd[1699]: error resolving pool 3.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
May 21 15:46:22 ada ntpd[1699]: error resolving pool ntp.ubuntu.com: Temporary failure in name resolution (-3)
May 21 15:46:24 ada ntpd[1699]: error resolving pool 2.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
May 21 15:47:23 ada ntpd[1699]: error resolving pool 1.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
May 21 15:47:25 ada ntpd[1699]: error resolving pool 3.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
May 21 15:47:27 ada ntpd[1699]: error resolving pool ntp.ubuntu.com: Temporary failure in name resolution (-3)
May 21 15:47:27 ada ntpd[1699]: error resolving pool 0.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
May 21 15:47:30 ada ntpd[1699]: error resolving pool 2.ubuntu.pool.ntp.org: Temporary failure in name resolution (-3)
</code></pre>
