Good day!
I am new to Linux in general. I've been trying to fix this issue for some time now reading other posts but I've had no luck. Here is what shows up on screen:
Picture of issue
Since the picture doesn't seem to work:
[ 0.144972] x86/CPU VMX (Outside TXT) disabled by BIOS /dev/sdb2: recovering journal /dev/sdb2: Superblock needs_recovery flag is clear, but journal has data /dev/sdb2: Run journal anyways /dev/sdb2: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY. (i.e., without -a or -p options) fsck exited with status code 4 The root filesystem on /dev/sdb2 requires a manual fsck
BusyBox v1.30.1 (Ubuntu 1:1.30.1-7ubuntu3) built-in shell (ash) Enter 'help' for a list of built-in commands.
(initramfs)
I have tried solutions posted on similar issues but none have worked. Maybe my case is a little different. Any suggestions on what I should do?
I have tried fsck error on boot: /dev/sda6: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY and the result is:
fsck.ext4 unable to set Superblock flags on /dev/sdb2 (Nextline) /dev/sdb2:
********* WARNING: Filesystem still has errors **********
karel
  • 122,292
  • 133
  • 301
  • 332
