Selecting previously unselected package viber.
(Reading database ... 151326 files and directories currently installed.)
Preparing to unpack viber.deb ...
Unpacking viber (21.8.0.11) ...
dpkg: dependency problems prevent configuration of viber:
 viber depends on libxcb-xinput0; however:
  Package libxcb-xinput0 is not installed.
dpkg: error processing package viber (--install):
 dependency problems - leaving unconfigured
Processing triggers for gnome-menus (3.36.0-1.1ubuntu3) ...
Processing triggers for desktop-file-utils (0.27-2build1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
 viber
karel
  • 122,292
  • 133
  • 301
  • 332
Whatever command you used to try to install viber.deb in 24.04 it was not a command of the form sudo apt install ./viber.deb which would have installed viber's required dependencies automatically. libxcb-xinput0 package is not installed which is creating dependency problems, so install it manually.
sudo apt install libxcb-xinput0
Then try to install viber.deb again.
karel
  • 122,292
  • 133
  • 301
  • 332
In my Ubuntu 24.04, I had the same error and I managed to install Viber with the following:
sudo apt install ./viber.deb --fix-broken
Christos
  • 233
