I have been using Ubuntu OS for a long time. I recently decided to install Ubuntu 24.04, but I encountered many problems and errors that made me unable to use it. First I got a purple screen with the Ubuntu logo, then I got a red text error, and after installing the OS I got a page that said: Something went wrong! Unfortunately I could not determine exactly where the problem is by looking at the console.
console log:
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Preconfiguring packages ...
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: E: Can not write log (Is /dev/pts mounted?) - posix_openpt (19: No such device)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Selecting previously unselected package grub2-common.
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: (Reading database ... 120210 files and directories currently installed.)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Preparing to unpack .../grub2-common_2.12-1ubuntu7_amd64.deb ...
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Unpacking grub2-common (2.12-1ubuntu7) ...
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Selecting previously unselected package grub-pc-bin.
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Preparing to unpack .../grub-pc-bin_2.12-1ubuntu7_amd64.deb ...
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Unpacking grub-pc-bin (2.12-1ubuntu7) ...
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Selecting previously unselected package grub-pc.
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Preparing to unpack .../grub-pc_2.12-1ubuntu7_amd64.deb ...
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Unpacking grub-pc (2.12-1ubuntu7) ...
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Selecting previously unselected package grub-gfxpayload-lists.
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Preparing to unpack .../grub-gfxpayload-lists_0.7build2_amd64.deb ...
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Unpacking grub-gfxpayload-lists (0.7build2) ...
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Setting up grub2-common (2.12-1ubuntu7) ...
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Setting up grub-pc-bin (2.12-1ubuntu7) ...
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Setting up grub-gfxpayload-lists (0.7build2) ...
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Setting up grub-pc (2.12-1ubuntu7) ...
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Creating config file /etc/default/grub with new version
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Processing triggers for install-info (7.1-3build2) ...
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Processing triggers for man-db (2.12.0-4build2) ...
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Running command ['udevadm', 'settle'] with allowed return codes [0] (capture=False)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: TIMED subp(['udevadm', 'settle']): 0.007
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Running command ['mount', '--make-private', '/target/usr/bin/ischroot'] with allowed return codes [0] (capture=False)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Running command ['umount', '/target/usr/bin/ischroot'] with allowed return codes [0] (capture=False)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Running command ['mount', '--make-private', '/target/sys'] with allowed return codes [0] (capture=False)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Running command ['umount', '/target/sys'] with allowed return codes [0] (capture=False)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Running command ['mount', '--make-private', '/target/run'] with allowed return codes [0] (capture=False)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Running command ['umount', '/target/run'] with allowed return codes [0] (capture=False)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Running command ['mount', '--make-private', '/target/proc'] with allowed return codes [0] (capture=False)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Running command ['umount', '/target/proc'] with allowed return codes [0] (capture=False)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Running command ['mount', '--make-private', '/target/dev'] with allowed return codes [0] (capture=False)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Running command ['umount', '/target/dev'] with allowed return codes [0] (capture=False)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Running command ['mount', '--bind', '/dev', '/target/dev'] with allowed return codes [0] (capture=False)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Running command ['mount', '--bind', '/proc', '/target/proc'] with allowed return codes [0] (capture=False)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Running command ['mount', '--bind', '/run', '/target/run'] with allowed return codes [0] (capture=False)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Running command ['mount', '--bind', '/sys', '/target/sys'] with allowed return codes [0] (capture=False)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Running command ['mount', '--bind', '/target/usr/bin/true', '/target/usr/bin/ischroot'] with allowed return codes [0] (capture=False)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Checking if target_proc (/target/proc) is a mount
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: It is, so unshare will use --mount-proc=/target/proc
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Running command ['unshare', '--fork', '--pid', '--mount-proc=/target/proc', '--', 'chroot', '/target', 'apt-get', 'clean'] with allowed return codes [0] (capture=False)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: TIMED subp(['udevadm', 'settle']): 0.006
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: finish: cmd-install/stage-curthooks/builtin/cmd-curthooks: SUCCESS: Installing packages on target system: ['grub-pc']
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/installing-missing-packages: SUCCESS: installing missing packages
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: start: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-iscsi-service: configuring iscsi service
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-iscsi-service: SUCCESS: configuring iscsi service
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: start: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-mdadm-service: configuring raid (mdadm) service
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-mdadm-service: SUCCESS: configuring raid (mdadm) service
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: start: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-nvme-over-tcp: configuring NVMe over TCP
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/configuring-nvme-over-tcp: SUCCESS: configuring NVMe over TCP
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: start: cmd-install/stage-curthooks/builtin/cmd-curthooks/installing-kernel: installing kernel
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: It's not, using normal behavior
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Running command ['unshare', '--fork', '--pid', '--', 'chroot', '/target', 'lsb_release', '--all'] with allowed return codes [0] (capture=True)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Running command ['dpkg', '--print-architecture'] with allowed return codes [0] (capture=True)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Updating apt sources in /target
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Running command ['unshare', '--fork', '--pid', '--mount-proc=/target/proc', '--', 'chroot', '/target', 'apt-get', '--quiet', '--option=Acquire::Languages=none', 'update'] with allowed return codes [0] (capture=False)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Running in chroot, ignoring command 'start'
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Get:1 file:/cdrom noble InRelease
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Ign:1 file:/cdrom noble InRelease
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Get:2 file:/cdrom noble Release [1,072 B]
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Reading package lists...
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: TIMED subp(['udevadm', 'settle']): 0.004
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Running command ['unshare', '--fork', '--pid', '--mount-proc=/target/proc', '--', 'chroot', '/target', 'apt-get', '--quiet', '--assume-yes', '--option=Dpkg::options::=--force-unsafe-io', '--option=Dpkg::Options::=--force-confold', 'install', '--download-only', 'linux-generic-hwe-24.04'] with allowed return codes [0] (capture=False)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Building dependency tree...
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Reading state information...
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: The following additional packages will be installed:
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: amd64-microcode bpfcc-tools bpftrace firmware-sof-signed hwdata ieee-data
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: intel-microcode iucode-tool libbpfcc libc-dev-bin libc-devtools libc6-dev
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: libclang-cpp18 libclang1-18 libcrypt-dev libllvm18 linux-firmware
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: linux-headers-6.8.0-31 linux-headers-6.8.0-31-generic
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: linux-headers-generic-hwe-24.04 linux-image-6.8.0-31-generic
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: linux-image-generic-hwe-24.04 linux-libc-dev linux-modules-6.8.0-31-generic
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: linux-modules-extra-6.8.0-31-generic linux-tools-6.8.0-31
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: linux-tools-6.8.0-31-generic linux-tools-common manpages-dev python3-bpfcc
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: python3-netaddr rpcsvc-proto thermald ubuntu-kernel-accessories
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Suggested packages:
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: glibc-doc fdutils linux-tools ipython3 python-netaddr-docs
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: The following NEW packages will be installed:
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: linux-generic-hwe-24.04 linux-headers-6.8.0-31
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: linux-headers-6.8.0-31-generic linux-headers-generic-hwe-24.04
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: linux-image-6.8.0-31-generic linux-image-generic-hwe-24.04 linux-libc-dev
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: linux-modules-6.8.0-31-generic linux-modules-extra-6.8.0-31-generic
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: linux-tools-6.8.0-31 linux-tools-6.8.0-31-generic linux-tools-common
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: manpages-dev python3-bpfcc python3-netaddr rpcsvc-proto thermald
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: ubuntu-kernel-accessories
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: 0 upgraded, 35 newly installed, 0 to remove and 0 not upgraded.
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Need to get 0 B/735 MB of archives.
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: After this operation, 1,073 MB of additional disk space will be used.
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Err:20 file:/cdrom noble/main amd64 linux-modules-6.8.0-31-generic amd64 6.8.0-31.31
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Hash Sum mismatch
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Hashes of expected file:
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: - SHA512:7416ae03d47edcce7ec0973ca201df231a65c8b86cb40be5b7e2213c6b53dacdeff18f6f8068dd7f8d9526ab134cba6ea4f98e654f3f99801834cfef80dacf29
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: - SHA256:3f17f2c279257eb50e40da44390bdf8272c440ca078831c348773d1314b5c2fe
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: - Filesize:38348992 [weak]
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Hashes of received file:
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: - SHA512:fa6f910e64951f3c20b3b3e2bcd300ad0537c8aeefce8dfab8d37cba11064a5f9073acfae7bb55ef6afc030d4c630869c0eae517a6188dac03d3a0456647b048
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: - SHA256:65980681a3d11e2ff40a6cb68c9ae435833042ead8f12a9711715974f162ae48
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Last modification reported: Sat, 20 Apr 2024 22:48:54 +0000
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: E: Failed to fetch file:/cdrom/pool/main/l/linux/linux-modules-6.8.0-31-generic_6.8.0-31.31_amd64.deb Hash Sum mismatch
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: E: Some files failed to download
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: TIMED subp(['udevadm', 'settle']): 0.008
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: finish: cmd-install/stage-curthooks/builtin/cmd-curthooks/installing-kernel: FAIL: installing kernel
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: finish: cmd-install/stage-curthooks/builtin/cmd-curthooks: FAIL: curtin command curthooks
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Traceback (most recent call last):
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: File "/snap/ubuntu-desktop-bootstrap/171/lib/python3.10/site-packages/curtin/commands/main.py", line 202, in main
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: ret = args.func(args)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: File "/snap/ubuntu-desktop-bootstrap/171/lib/python3.10/site-packages/curtin/commands/curthooks.py", line 2224, in curthooks
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: builtin_curthooks(cfg, target, state)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: File "/snap/ubuntu-desktop-bootstrap/171/lib/python3.10/site-packages/curtin/commands/curthooks.py", line 2048, in builtin_curthooks
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: install_kernel(cfg, target)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: File "/snap/ubuntu-desktop-bootstrap/171/lib/python3.10/site-packages/curtin/commands/curthooks.py", line 393, in install_kernel
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: install(kernel_package)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: File "/snap/ubuntu-desktop-bootstrap/171/lib/python3.10/site-packages/curtin/commands/curthooks.py", line 369, in install
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: distro.install_packages([pkg], target=target, env=env)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: File "/snap/ubuntu-desktop-bootstrap/171/lib/python3.10/site-packages/curtin/distro.py", line 473, in install_packages
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: return install_cmd('install', args=pkglist, opts=opts, target=target,
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: File "/snap/ubuntu-desktop-bootstrap/171/lib/python3.10/site-packages/curtin/distro.py", line 255, in run_apt_command
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: cmd_rv = apt_install(mode, args, opts=opts, env=env, target=target,
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: File "/snap/ubuntu-desktop-bootstrap/171/lib/python3.10/site-packages/curtin/distro.py", line 303, in apt_install
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: cmd_rv = inchroot.subp(cmd + dl_opts + packages, env=env,
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: File "/snap/ubuntu-desktop-bootstrap/171/lib/python3.10/site-packages/curtin/util.py", line 843, in subp
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: return subp(*args, **kwargs)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: File "/snap/ubuntu-desktop-bootstrap/171/lib/python3.10/site-packages/curtin/util.py", line 323, in subp
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: return _subp(*args, **kwargs)
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: File "/snap/ubuntu-desktop-bootstrap/171/lib/python3.10/site-packages/curtin/util.py", line 172, in _subp
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: raise ProcessExecutionError(stdout=out, stderr=err,
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: curtin.util.ProcessExecutionError: Unexpected error while running command.
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Command: ['unshare', '--fork', '--pid', '--mount-proc=/target/proc', '--', 'chroot', '/target', 'apt-get', '--quiet', '--assume-yes', '--option=Dpkg::options::=--force-unsafe-io', '--option=Dpkg::Options::=--force-confold', 'install', '--download-only', 'linux-generic-hwe-24.04']
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Exit code: 100
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Reason: -
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Stdout: ''
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Stderr: ''
May 08 21:48:55 ubuntu subiquity_log.3824[10918]: Unexpected error while running command.
May 08 21:48:55 ubuntu subiquity_event.3824[3824]: executing curtin install curthooks step
May 08 21:48:55 ubuntu subiquity_event.3824[3824]: installing system
May 08 21:48:55 ubuntu subiquity_event.3824[3824]: curtin command install
guiverc
  • 33,561
Crashofs
