19
I just installed Ubuntu Server on a VPS.
To configure the server I'm reading the Ubuntu Server Guide. But the Ubuntu Server Guide doesn't tells me everything.
E.g. The Ubuntu Server Guide doesn't tell me about how to secure SSH, which is, in my opinion, an important thing to do after installation of a server.
I know that I've to secure SSH access, but I might forget things to configure. Because I don't know what I don't know.
Does a complete guide exists which tells me which important things I've to after installing Ubuntu server? If not, can anyone tell me those things?
OrangeTux
  • 5,275
Secure shared memory
/dev/shm can be used in an attack against a running service, such as httpd. Modify /etc/fstab to make it more secure.
Open a Terminal Window and enter the following :
sudo vi /etc/fstab
Add the following line and save. You will need to reboot for this setting to take effect :
tmpfs     /dev/shm     tmpfs     defaults,noexec,nosuid     0     0
Harden network with sysctl settings
The /etc/sysctl.conf file contain all the sysctl settings. Prevent source routing of incoming packets and log malformed IP's enter the following in a terminal window
sudo vi /etc/sysctl.conf
Edit the /etc/sysctl.conf file and un-comment or add the following lines :
# IP Spoofing protection
net.ipv4.conf.all.rp_filter = 1
net.ipv4.conf.default.rp_filter = 1
# Ignore ICMP broadcast requests
net.ipv4.icmp_echo_ignore_broadcasts = 1
# Disable source packet routing
net.ipv4.conf.all.accept_source_route = 0
net.ipv6.conf.all.accept_source_route = 0
net.ipv4.conf.default.accept_source_route = 0
net.ipv6.conf.default.accept_source_route = 0
# Ignore send redirects
net.ipv4.conf.all.send_redirects = 0
net.ipv4.conf.default.send_redirects = 0
# Block SYN attacks
net.ipv4.tcp_syncookies = 1
net.ipv4.tcp_max_syn_backlog = 2048
net.ipv4.tcp_synack_retries = 2
net.ipv4.tcp_syn_retries = 5
# Log Martians
net.ipv4.conf.all.log_martians = 1
net.ipv4.icmp_ignore_bogus_error_responses = 1
# Ignore ICMP redirects
net.ipv4.conf.all.accept_redirects = 0
net.ipv6.conf.all.accept_redirects = 0
net.ipv4.conf.default.accept_redirects = 0
net.ipv6.conf.default.accept_redirects = 0
# Ignore Directed pings
net.ipv4.icmp_echo_ignore_all = 1
To reload sysctl with the latest changes, enter:
sudo sysctl -p
Prevent IP Spoofing
Open a Terminal and enter the following :
sudo vi /etc/host.conf
Add or edit the following lines :
order bind,hosts
nospoof on
Harden PHP for security
Edit the php.ini file :
sudo vi /etc/php5/apache2/php.ini
disable_functions = exec,system,shell_exec,passthru
register_globals = Off
expose_php = Off
magic_quotes_gpc = On
Web Application Firewall - ModSecurity
http://www.thefanclub.co.za/how-to/how-install-apache2-modsecurity-and-modevasive-ubuntu-1204-lts-server
Protect from DDOS (Denial of Service) attacks - ModEvasive
Scan logs and ban suspicious hosts - DenyHosts and Fail2Ban
@DenyHosts
DenyHosts is a python program that automatically blocks SSH attacks by adding entries to /etc/hosts.deny. DenyHosts will also inform Linux administrators about offending hosts, attacked users and suspicious logins.
sudo apt-get install denyhosts
After installation edit the configuration file /etc/denyhosts.conf and change the email, and other settings as required.
To edit the admin email settings open a terminal window and enter:
sudo vi /etc/denyhosts.conf
Change the following values as required on your server :
ADMIN_EMAIL = root@localhost
SMTP_HOST = localhost
SMTP_PORT = 25
#SMTP_USERNAME=foo
#SMTP_PASSWORD=bar
SMTP_FROM = DenyHosts nobody@localhost
#SYSLOG_REPORT=YES
@ Fail2Ban
Fail2ban is more advanced than DenyHosts as it extends the log monitoring to other services including SSH, Apache, Courier, FTP, and more.
Fail2ban scans log files and bans IPs that show the malicious signs -- too many password failures, seeking for exploits, etc.
Generally Fail2Ban then used to update firewall rules to reject the IP addresses for a specified amount of time, although any arbitrary other action could also be configured. Out of the box Fail2Ban comes with filters for various services (apache, courier, ftp, ssh, etc).
sudo apt-get install fail2ban
After installation edit the configuration file /etc/fail2ban/jail.local and create the filter rules as required.
To edit the settings open a terminal window and enter:
sudo vi /etc/fail2ban/jail.conf
Activate all the services you would like fail2ban to monitor by changing enabled = false to *enabled = true*
For example if you would like to enable the SSH monitoring and banning jail, find the line below and change enabled from false to true. Thats it.
[ssh]
enabled  = true
port     = ssh
filter   = sshd
logpath  = /var/log/auth.log
maxretry = 3
If you would like to receive emails from Fail2Ban if hosts are banned change the following line to your email address.
destemail = root@localhost
and change the following line from :
action = %(action_)s
to:
action = %(action_mwl)s
You can also create rule filters for the various services that you would like fail2ban to monitor that is not supplied by default.
sudo vi /etc/fail2ban/jail.local
Good instructions on how to configure fail2ban and create the various filters can be found on HowtoForge - click here for an example
When done with the configuration of Fail2Ban restart the service with :
sudo /etc/init.d/fail2ban restart
You can also check the status with.
sudo fail2ban-client status
Check for rootkits - RKHunter and CHKRootKit.
Both RKHunter and CHKRootkit basically do the same thing - check your system for rootkits. No harm in using both.
sudo apt-get install rkhunter chkrootkit
To run chkrootkit open a terminal window and enter :
sudo chkrootkit
To update and run RKHunter. Open a Terminal and enter the following
sudo rkhunter --update
sudo rkhunter --propupd
sudo rkhunter --check
Scan open ports - Nmap
Nmap ("Network Mapper") is a free and open source utility for network discovery and security auditing.
sudo apt-get install nmap
Scan your system for open ports with :
nmap -v -sT localhost
SYN scanning with the following :
sudo nmap -v -sS localhost
Analyse system LOG files - LogWatch
Logwatch is a customizable log analysis system. Logwatch parses through your system's logs and creates a report analyzing areas that you specify. Logwatch is easy to use and will work right out of the package on most systems.
sudo apt-get install logwatch libdate-manip-perl
To view logwatch output use less :
sudo logwatch | less
To email a logwatch report for the past 7 days to an email address, enter the following and replace mail@domain.com with the required email. :
sudo logwatch --mailto mail@domain.com --output mail --format html --range 'between -7 days and today'
Audit your system security - Tiger.
Tiger is a security tool that can be use both as a security audit and intrusion detection system.
sudo apt-get install tiger
To run tiger enter :
sudo tiger
All Tiger output can be found in the /var/log/tiger
To view the tiger security reports, open a Terminal and enter the following :
sudo less /var/log/tiger/security.report.*
For More Help
One Zero
  • 27,761
Ubuntu is quite secure by default, as well as SSH is.
The most important thing is :
  1. Do not use a weak password for your user as 12345 or qwerty...
  2. Do not activate the root account
  3. Use Fail2ban or every similar software to avoid bruteforce login
  4. Check your logs regulary to see if everything is ok
  5. Install only what you need on the server and configure it carefully, I mean really read the docs deeply for every soft you use especially for mail server.
If you play that way it should be ok. Oh, and of course, make some regular backups :)
x_vi_r
  • 283
