I tried to install mailman3-full package to fresh install of Ubuntu 24.04 but the installation fails. The command I used was plain
apt install mailman3-full
Any ideas how to circumvent the problem?
The installation seems to work quite for long but then there are eror messages (I clipped most of the successful log and started before the real problems started)
dbconfig-common: writing config to /etc/dbconfig-common/mailman3-web.conf
creating database mailman3web.db: success.
verifying database mailman3web.db exists: success.
/usr/lib/python3/dist-packages/django_q/conf.py:174: UserWarning: Retry and timeout are misconfigured. Set retry larger than timeout,failure to do so will cause the tasks to be retriggered before completion.See https://django-q2.readthedocs.io/en/master/configure.html#retry for details.
warn(
Traceback (most recent call last):
File "/usr/bin/django-admin", line 33, in <module>
sys.exit(load_entry_point('Django==4.2.11', 'console_scripts', 'django-admin')())
File "/usr/lib/python3/dist-packages/django/core/management/__init__.py", line 442, in execute_from_command_line
utility.execute()
File "/usr/lib/python3/dist-packages/django/core/management/__init__.py", line 416, in execute
django.setup()
File "/usr/lib/python3/dist-packages/django/__init__.py", line 24, in setup
apps.populate(settings.INSTALLED_APPS)
File "/usr/lib/python3/dist-packages/django/apps/registry.py", line 124, in populate
app_config.ready()
File "/usr/lib/python3/dist-packages/allauth/account/apps.py", line 15, in ready
raise ImproperlyConfigured(
django.core.exceptions.ImproperlyConfigured: allauth.account.middleware.AccountMiddleware must be added to settings.MIDDLEWARE
ESC[0mdpkg: error processing package mailman3-web (--configure):
installed mailman3-web package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of mailman3-full:
mailman3-full depends on mailman3-web; however:
Package mailman3-web is not configured yet.
dpkg: error processing package mailman3-full (--configure):
dependency problems - leaving unconfigured
mailman3-web
mailman3-full
needrestart is being skipped since dpkg has failed
Thank you for any support!
