-1
Summary: is there a way to get apt to build the kernel on a different partition and then copy it over the existing one?
My /boot partition is very small (88MB) and has only a single version of the kernel installed. The initrd file is 36MB, which is 4x as large as it used to be. I'm in a stuck state where apt can't run because a stuck package is trying to generate a new initrd file, but there's not enough space on /boot. :/
How can I get apt to generate a trimmed-down initrd file using /tmp, and then copy it over the original on /boot?
$ df -h / /boot
Filesystem      Size  Used Avail Use% Mounted on
/dev/sda3        72G   58G   10G  86% /
/dev/sda1        88M   56M   26M  69% /boot
$ du -sh /boot/* 187K /boot/config-4.4.0-170-generic 6.7M /boot/grub 36M /boot/initrd.img-4.4.0-170-generic 179K /boot/memtest86+.bin 181K /boot/memtest86+.elf 181K /boot/memtest86+_multiboot.bin 3.8M /boot/System.map-4.4.0-170-generic 6.9M /boot/vmlinuz-4.4.0-170-generic
$ sudo apt -f install Reading package lists... Done Building dependency tree
Reading state information... Done 0 upgraded, 0 newly installed, 0 to remove and 63 not upgraded. 2 not fully installed or removed. After this operation, 0 B of additional disk space will be used. Setting up initramfs-tools (0.122ubuntu8.16) ... update-initramfs: deferring update (trigger activated) Setting up linux-firmware (1.157.23) ... update-initramfs: Generating /boot/initrd.img-4.4.0-170-generic
gzip: stdout: No space left on device E: mkinitramfs failure cpio 141 gzip 1 update-initramfs: failed for /boot/initrd.img-4.4.0-170-generic with 1. dpkg: error processing package linux-firmware (--configure): subprocess installed post-installation script returned error exit status 1 Processing triggers for initramfs-tools (0.122ubuntu8.16) ... update-initramfs: Generating /boot/initrd.img-4.4.0-170-generic
gzip: stdout: No space left on device E: mkinitramfs failure cpio 141 gzip 1 update-initramfs: failed for /boot/initrd.img-4.4.0-170-generic with 1. dpkg: error processing package initramfs-tools (--configure): subprocess installed post-installation script returned error exit status 1 Errors were encountered while processing: linux-firmware initramfs-tools E: Sub-process /usr/bin/dpkg returned an error code (1)
Phrogz
  • 1,712
Per this answer I modified /etc/initramfs-tools/initramfs.conf and to use MODULES=most. I then ran sudo update-initramfs -c -k $(uname -r), which built a new initrd image that was only 13MB instead of 33MB. I was then able to run sudo apt -f install to successfully fix my packages.
Changing the configuration to use COMPRESS=xz further reduced the file size down to just 8MB.
Phrogz
  • 1,712
